Esp light/climate/key fob opening/ help!!!!!!
sabs46
NULL
Hi guys,
Yes i have the above probs.I know they get discussed a lot but i am now pulling my hair out...
1. First got esp light on dash, climate control turns off and indicators did not register on dash but did work.(started intermittent but now all the time)
replaced brake switch as suggested ..no effect
2. key fob stops opening door, opened car(well my father did as i was away) manually, alarm sounded i believe. Battery ran flat, i assume indicators were left flashing (which they now constantly) as alarm was triggered.
3. read articles suggesting car battery fault, replaced battery no dif.o and tried reprogramming remotes didn't work
4. ran diagnostics cleared faults, came back with:-
Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AC Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 63351 VCID: 62C0798CC4C9
No fault code found.
Cleared and ran another:-
-------------------------------------------------------------------------------Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 01011 Shop #: WSC 63351 VCID: 438E9C087B13
-------------------------------------------------------------------------------Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl Part No: 8E0 959 433 BD Component: Komfortgerát TBF 1712 Coding: 06859 Shop #: WSC 63351 VCID: 74EC0FD46E3D
Part No: 8E2959802B Component: Tõrsteuer.FS BRM 0205
Part No: 8E2959801B Component: Tõrsteuer.BF BRM 0205
No Faults Found or DTCs not supported by controller or a communication error occurred
So before i start pulling money for dual climate or/and steering column control..
Any ideas please..........:ermm:
Tried another diagnostics check after checking fuses( strangely interior ligt started working again as had been off, fuse was ok tho)
Saturday,15,January,2011,19:07:39:09663
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8EX5A058553 Mileage: 73130km/45440miles
Coding: 00000
Shop #: WSC 63351
VCID: 62C0798CC4C9
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 3E78EDFC10F1
Coding: 01011
Shop #: WSC 63351
VCID: 438E9C087B13
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00401
Shop #: WSC 00762
VCID: 336ECCC82BB3
WAUZZZ8EX5A058553 AUZ6Z0D0326259
1 Fault Found:
00457 - Control Module for Network (J519)
49-00 - No Communications
Coding: 06859
Shop #: WSC 63351
VCID: 74EC0FD46E3D
Part No: 8E2959802B
Part No: 8E2959801B
No Faults Found
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 M
Component: symphony II PM6 0410
Coding: 01201
Shop #: WSC 00512
VCID: 3162C6C0D1AF
