Badger5Chris Nott
Results 1 to 8 of 8
    Gibonz's Avatar
    Vorsprung Durch Technik
    Jun 2008
    111
    Help! Drivers Door Wont Open! 2002 A4
    Hey Guys,
    Drove to work this morning and when i went to get out of the car, the bloody door wouldnt open!
    Tried the key fob etc but nothing worked had to climb out the passenger door!
    Anyone had this happen before and what could the possible causes be?
    Gib
    3.0 V6 Quattro LPG
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    probably broken wire in the flex hose between the car and the door or water has got in there
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
    Gibonz's Avatar
    Jun 2008
    111
    Could be mate
    Is this a dealer fix or can it be sorted elsewhere you think?
    3.0 V6 Quattro LPG
    dsmclark40v's Avatar
    Sep 2006
    Hampshire
    715
    Does it still open from the outside? if so its defiantly the cable or the bracket on the handle. Dealer can fix it for you if you want to pay their expensive labour rate. best off going to a good indy
    Sam,
    Gone
    Gibonz's Avatar
    Jun 2008
    111
    Wont open inside or out, also tried the actual key in the keyhole, still nothing.
    Price the wire at Audi which is 5 and a lock at 130
    Would it just be the wire you think?
    And can it be repaired from the outside by taking the handle off?
    3.0 V6 Quattro LPG
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    you basically need to get the door open somehow and then you can peel back the rubber sleeve/take the conneection block off to check for water/broken wires.
    As to how you get the door open, no idea sorry?
    a4 3.0 qu...ro sport
    Nov 2008
    20
    hi. i had same problem last summer and it was a batterys foult also had various other electrical issues but when i changed battery everything was fine
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    I had this back in September, very very weird. It wouldn't open for about 2 or 3 days, it was seriously peeing me off! Literally the day before I was about to take it somewhere to be sorted it mysteriously started working again and I could open my door from both sides! It's been working perfectly fine ever since.
    So it must of had a hissy moment. Hopefully yours is doing the same and will sort it's life out in a day or two?!
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
