Sky InsuranceBadger5
    Oct 2004
    Norwich
    Speed accuracy on GPS systems: Navman, Road Angel
    Perhaps not really an item for this post, but its the section of the site I use most often, so anyway:
    I've just bought a Navman 510. (Awesome by the way) When travelling at any speed, the Navman speed always shows 3 mph slower than the actual speed I am travelling, as indicated by my car's speedo.
    I recently noticed the same thing when travelling in a taxi. The guy had a Road Angel and this showed approx 6 mph slower than the car's speedo.
    I could understand a bit of intolerance when speeding up or slowing down because it must take a second or so for the GPS system to relay back to the satellite, but when travelling at a fixed speed, i.e. with cruise on, why is there a difference? Which is correct, car or Nav system?
    I would have thought that the car's speedo is more accurate only because of the distance the satellites are from the Navigation system, and I assume potential inaccuracies. [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Has anybody ever tried for instance measuring their cars speed against a radar gun or any other system for accuracy??
    Just a topic for conversation, but would be interested for your thoughts.
    imported_GezzerS4
    Re: Speed accuracy on GPS systems: Navman, Road Angel
    The speed showing on the Nav equipment via GPS is 100% Near as makes no difference when travelling at a constant speed, there is a slight delay when changing speed, due to calculations and signal travel, the area where GPS is less accurate is in determining Altitude due to satellite position with regards to triangulation calculations, but the systems we use in our cars do not use this anyway, but it could in theory distort your Speed over Ground (SOG) if you are descending or climbing a long steep hill at high speed, more sophisicated systems used in high end commercial and military uses take this into account but for our purposes ignore it.
    [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    scoTTy's Avatar
    Essex, UK
    1,958
    My S4 is always within 1-2mph of the gps.
    a4sline190's Avatar
    Nov 2004
    Scotland
    149
    got the tom tom go and is around 1-2 mph slower than speedo, guess thats pretty accurate as all speedos generally over estimate speed to allow for a margin of error.
