Badger5Chris Nott
Page 2 of 2 FirstFirst 12
Results 41 to 67 of 67
  1. #41
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    Well,AVF have a stronger clutch,240mm vs 228mm AVX;some people says the extra 25nm came for the map,other people says came from the gearbox;to be honest,i dont know the true.
    But bowth engines technical are the same.
    AVF cant take 450nm till 500nm
    AWX cant take till 400nm,most remaps are 370-380nm tourque
    B6 1,9TDI AVF SPORT QUATTRO AVANT
    Mods:RNS-e sat nav,Bluetooth,Rear camera,Full led interior/exterior,Cobra PCD,S4 B5 front brakes,S line body kit+S4 door blades,S line gear knob,RS4 B7 handbrake,RS6 wheels,EGR deleted,cruise control,custom leather & alcantara seats,tinted windows,A4 B7 arms & wiper blades,BV43 turbo,FMIC,custom remap(around 200hp and 368lb/ft tourque)
  3. #42
    simon.m's Avatar
    Oct 2009
    2,746
    i think mine is the AVB engine being the 100bph
  4. #43
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    AVB is good in fuel economy,but not so great in power:
    AVB 12,1sec 0-62mph
    AVW,AVF 9,9sec 0-62mph
  5. #44
    simon.m's Avatar
    Oct 2009
    2,746
    It gets me there lol
  6. #45
    Bari's Avatar
    Mar 2011
    Paços de Ferreira, Portugal
    96
    i think makes difference on the turbo
    100hp - gt15
    115 gt1749v
    130 gt1749va
  7. #46
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    Quote Originally Posted by ASHIHARA View Post
    Diference between 101hp and 131hp are turbo,injectors,diferent map,diferent internals,diferent flywheel and clutch,so they are a lot at diferences
    I just explained the diferences,they are not only on the turbo.
  8. #47
    Bari's Avatar
    Mar 2011
    96
    right :D
  9. #48
    Jul 2007
    London
    3,258
    Quote Originally Posted by Bari View Post
    i think makes difference in the turbo
    100hp - gt15
    115 gt1749v
    130 gt1749va
    They are all technically GT 15 but Garrett are making the matters even more confusing when they are reffered as VNT1749x(x) ?! The 110Bhp VE and 115Bhp PD IS the same GT1749v turbocharger(the later has a larger intercooler and higher injector pressures hence the low bhp difference but the Nm increase), the pd 130 is a GT1749VA(few mm bigger compressor wheel), the golf/bora PD 150 is a GT1749VB (the largest fitted VNT17 with integral manifold) wich feature a new mix of alloy and can sustain higher boost and higher EGT. This wont fit a longitudinal engine as its mounted the wrong way.
    FOR SALE:
  10. #49
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    Turbos 150hp pd are not mounted in the wrong way,they are just for transversal engines
  11. #50
    Jul 2007
    London
    3,258
    I meant they are clocked the wrong way for a longitudinal engine and under the bulkhead as opposed to beeing on top compared to the passat (bit like my girlfriend when we make sex: she wants me to be on top and i wanna be under !)...
    FOR SALE:
  12. #51
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    I know what u mean ;anyway,good udpgradet for longitudinal engines is pd 170hp turbo bv43,is plug and play.Im use one for myself.
  13. #52
    Bari's Avatar
    Mar 2011
    96
    right... i want one too
  14. #53
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    Ha,ha,ha,u have a bigger turbo like bv43
  15. #54
    Bari's Avatar
    Mar 2011
    96
    not now.. i sold the 2260 and i have gt1749va again lol
  16. #55
    Jan 2011
    Gainsborough
    68
    Don't see how it could be the gearbox as torque / bhp is measured at flywheel for manufacturers figures, must be map
  17. #56
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    U right,i didnt think about that
  18. #57
    Jan 2011
    Gainsborough
    68
    No worries mate! Can I ask why brakes from a B5?
  19. #58
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    They are from S4 B5,not for B5;2 piston caliper,321mm discs and a very good improvment in breaking and also cheaper:100 calipers second hand,70 pagid brake discs and 110 ferodo premier brake pads,so 290 to have good brakes
    Image codes: IMAG0317
    Image codes: IMAG0318
    Image codes: IMAG0320
    Image codes: IMAG0321
  20. #59
    Bari's Avatar
    Mar 2011
    96
    and they are plug and play
  21. #60
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    yes,they are;the only thing is you must have ET43 wheels 17 or 18inch,or u have to use wheel spacers;16inch wheel dont fit s4 calipers!
    @Bari,why u sold that turbo?why dont u go bigger?,like 3,0tdi 240hp turbo?Is true,in this case injectors dont have flow and is underfueel
  22. #61
    Bari's Avatar
    Mar 2011
    96
    yes, in that case better injectores will be needed...
    here in Portugal we have Ibizas PD 130 with more than 300hp, i know one with 370
    but the engine blows... i think
  23. #62
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    Yes,is true,stock engine cant handle more 250hp,i think 200hp is safe on long term.
  24. #63
    Bari's Avatar
    Mar 2011
    96
    yes it is
    for 200hp kkk bv43 is enough
  25. #64
    Jun 2012
    Teesside
    448
    Sorry to drag this thread up, but with the bv43 turbo bolted onto awx engine and good map will the injectors need upgrading or are they ok with the standard ones?
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
  26. #65
    Mar 2012
    163
    Quote Originally Posted by Dan TheMan Welburn View Post
    i would like to know this, but for a avf engine.
    Cheers,
  27. #66
    Jul 2007
    London
    3,258
    The stock injectors are fine with just the BV43...
    FOR SALE:
  28. #67
    Sep 2007
    20
    Quote Originally Posted by adamss24 View Post
    100 Bhp 250Nm
    115 Bhp 285Nm
    130 Bhp AWX 285 Nm 5 speed manual
    130 Bhp AVF 310 Nm (sport 6 speed manual)
    130 Bhp AVF/AWX 285 Nm auto only.
    There was no 115 Bhp pd engine fitted to the b6 audi a4 or audi a6 c5, the 115 Bhp ATJ engine was a passat b5 and audi a4 b5 only engine and prone to porous heads/overheating. They are not the same, the 130bhp got stronger rods and pistons. There is also the ARL 150 Bhp fitted in the golf, also different rods, injectors and turbo + agressive map and a 160 Bhp lump fitted to the seat ibiza cupra wich is a ARL with a factory remap.
    Dont want to come across as rude, but I own a 04 1.9 TDI A4 Avant Sport. Its a 115. Almost certain its PD. Engine code BKE.
