Badger5EM Tuning
Results 1 to 18 of 18
Thread: EGR cleaning
    Aug 2009
    Durham
    110
    EGR cleaning
    I'm thinking of cleaning my egr on my 1.9 tdi do you guys have any advice on what to do and use for cleaning,car got 140k on it and the EGR is leaking a bit,is it worth buying a new one or just clean it.
    deanski's Avatar
    wax on, wax off
    May 2010
    Lancashire
    374
    clean it and failing that blank it. IMO they arent worth replacing. they're a stupid idea and expensive to replace. all IMO of course lol.
    simon.m's Avatar
    Oct 2009
    2,746
    is it hard to blank it off ? dose the car not need it then ? last ? what would the benafit be if its blanked off ?
    Sep 2005
    Staffordshire, UK
    455
    I could do with these answers too!
    Audi Avant A4 54 1.9Tdi Quattro & Leon Cupra R 2005 1.8T remapped to 275bhp
    A4 b6 TDI V6 Quattro Sport
    Nov 2010
    West london
    150
    No the car doesn't need it
    The car will run slightly cooler in as much as act (air charge temp)
    And in turn will give not alot but a tiny bhp gain If I'm correct and it also frees up some space under the bonnet
    And if your ok with some spanners it's fairly easy you will need two blanking plates and a bolt for the little vacuum hose then job done that's as long as it's a manual one if it has an electrical connection on it then I'm not sure if the car relies on it or not but my a4 2.5 v6 tdi is egr deleted and is fine
    Hope this helps fella
    Sep 2005
    Staffordshire, UK
    455
    EGR Valve Blanking Plate, Vw Audi Skoda T4 T5 tdi on eBay (end time 13-Jan-11 15:57:49 GMT)
    This would suit and 2 of them I guess?
    Can anyone confirm 1.9tdi is OK to do this on?
    did you have to delete it in VAG com?
    Nov 2010
    West london
    150
    Nope I didnt have to mate if you look at it and see if the egr valve has wires going to it you prob will have to delete it of the software too
    And yeah you will need 2 of the blanking plates and any gaskets to
    Good luck mate
    Aug 2009
    Durham
    110
    what would you use to clean it,would i need to get new gaskets to?
    simon.m's Avatar
    Oct 2009
    2,746
    you can buy an egr cleaner from any good car shop for a few pounds and id say yes to a new gaskets mate if your taking it off best to put new ones on
    ADC74's Avatar
    Master Baker
    Jan 2011
    Staffordshire
    148
    I always use carb cleaner, works a treat
    ATR vs V6 TDI
    simon.m's Avatar
    Oct 2009
    2,746
    just make sure its for tdis then ;-)
    ADC74's Avatar
    Master Baker
    Jan 2011
    Staffordshire
    148
    Didn't realise it made a difference, but then again I'm a derv virgin
    Thanks for that Simon
    ATR vs V6 TDI
    Sep 2005
    Staffordshire, UK
    455
    Does anyone have any infor about blanking the EGR on a 1.9tdi can't find any anywhere
    way318's Avatar
    Jan 2009
    Merseyside
    160
    Try looking on tdisport forum, there will be info on there about EGR blanking etc.
    I am going to do mine when the weather is a bit better. I've already bought the blanking plates and they only cost 4.50 for 2 off ebay. I can give you the guys email address if you want it?
    On the 1.9 TDi (AWX engine code) to get the EGR Valve off to clean it you also need to remove the exhaust manifold so you can access all the bolts which secure the EGR Valve to the manifold.
    My plan is to blank it off first, then when its alot warmer do the cleaning bit. To blank it off all you need to do is remove the pipe that connects between the EGR Valve & the exhaust manifold and then put a blanking plates we the pipe used to bolt to, one on the back of the EGR valve and one on the manifold.
    Don't forget this info is for the AWX engine code, so may not be correct for your's. But I think the principle is the same.
    The EGR will leak and thats normal, my A4 is on 152K and is doing the same.
    Aug 2009
    Durham
    110
    thanx mines a AWX engine code so i didnt know that,is that easy to remove?
    way318's Avatar
    Jan 2009
    Merseyside
    160
    Quote Originally Posted by choimaloy View Post
    In principle, yes. But will let you know when i do it.
    If you do your's before I manage to do mine, let me know how you get on and vice versa.
    Avant4me's Avatar
    The're Graphite not black!!
    Mar 2010
    Bristol
    257
    Exhaust removal seems a pain in the ass, but need to do mine, as it smokes a lot when i boot it
    Official Fan Club member No 001!!
    braf89's Avatar
    Apr 2010
    Mayo, Rep. of Ireland
    I dont think theres any need for the blanking plates. A audi mechanic blanked my girlfriends awx and all he did was put a ball bearing in the vaccum hose and clear it on the computer. I have it done for about a month now and its perfect no problems since.
