EM TuningVolks Autos
Results 1 to 33 of 33
    Jan 2011
    Question Do i have can bus wiring/ system
    Hello All .Driving Audi A4 3.0 sport quattro 2001 and planning to instal hid kit phillips one. the main question is
    does my car got can bus or k line wiring (system) please for help ,how to recognize them??
    And if i have can-bus in whitch models they start installing it im asking about years .
    Thank you very much for any help.
    19scotty81's Avatar
    Push down and across !!!!!!!!!
    Dec 2010
    Newcastle Upon Tyne
    107
    Hi, can't really answer your question but, did you know from Jan 1st 2012 hid kits are gonna be an MOT failure from what i gather, just thought i'd mention
    A4 nut's Avatar
    wolverhampton
    352
    Quote Originally Posted by 19scotty81 View Post
    Even if you have headlamp wash?
    Hope the people that took me DIE
    27,115
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    Quote Originally Posted by A4 nut View Post
    yes unless you have self leveling suspension
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Dont forget remapping.
    New MOT Legislations
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Hi
    All hid retro fit systems are going to fail an MOT from 31st DEC 2011 at the latest
    Unless they meet type approval which is
    1. proper hid light unit specifically designed for gas discharge lighting
    2. Self leveling headlight system
    3. headlamp washers
    You will also fail with a remap they say but this will only be for the tuning box people
    as an ecu remap is basically undetectable
    Air bag faults so lights on or not working in accordance with manufacturer
    and there is going to be a wiring loom inspection so everything is safe and secure basically
    From what ive read this also now means insecure batteries are going to be a fail as at the moment the word Battery isnt in the testers manual so has never been a fail.
    Its all here if anyone wants a read
    does get a bit boring thou
    http://eur-lex.europa.eu/LexUriServ/...47:0072:EN:PDF
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by paul20v View Post
    Hi
    3. headlamp washers
    The benefit of it a tuning box is it can be easily removed and replaced at a later date if needs be! I've not read the link, but do they say why they're making them a fail? Surely as long as the emissions are within limit thats all that matters?
    It will be interesting to see how far they will take the HID thing, in mine the ballasts will be an instant giveaway, but if they're installed under the light will they go to the bother of taking the back of the light unit. The 6000k colour is a bit of a giveaway, but the lower K bulbs colour can be matched by xenon look halogen bulbs these days.
    Sep 2003
    Bournemouth
    312
    To be honest i'm glad they are doing this, there's too many chavs driving around with very bright hids that are way out of adjustment blinding oncoming traffic. God i must be getting old sound like my father now
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    It says any modification to the engine ecu ,
    now this in my eyes leaves a very open criteria for failing
    as i said you cant see the remap and testing stations will not have anyway of searching ecus for maps
    the box on the other hand is quite often in a place you can see
    also this has nothing todo with emmisions passing or failing they can still pass and performance alterations will be a fail
    how this is all going to be worded is in the link if thats the final draft of the testers manual that we will get time will tell
    again with the Hid s if they explain under methods of inspection what to look out for when a Discharge light fires up for example there will be nothing we can do only not have them in for test
    again all dependes on the final wording .
    scott b's Avatar
    1,254
    at the moment they cant remove anything from the car to check stuff, ie brake pads, they cant remove the wheel trim/wheel but if they can see through the wheel (ie alloy wheel) and see that the brake pads are below 1mm then i think they can fail it
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Quote Originally Posted by scott b View Post
    Correct but in this case most pads can be seen from underneath
    but you are right testers are not allowed to remove fixed items from vehicles.
    Mar 2008
    Dorset
    13,856
    I've no doubt these items are easy enough to spot by a tester, I can understand why HID's are being regulated as poorly fitted one's in inappropriate headlights are dangerous. I also think anything above 6000k should be banned as they're too blue, in my opinion anyway.
    I just don't see the problem with a remap/tuning box. If thats true then thats a lot of business under threat.
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Its 100% true
    and i couldnt agree more i dont see why the marginal increase in power or any power increase should have anything todo with road safety as an MOT issue ,
    They could argue your brakes are not upto it but then if you have a set of 321mm brakes on as i do whats the issue there then .
    Mar 2008
    Dorset
    13,856
    Standard A4 headlights are far more dangerous than HID'd ones!
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Your not wrong there .
    scott b's Avatar
    1,254
    with regards the ecu:
    6.1.9. Engine performance
    Visual inspection
    (a) Control unit illegal modified (b) illegal engine modification
    but is it illegal to remap a car?
    Jun 2010
    196
    im with you there its a grey area i think it will be down to mot testers opinion as illigal to me is load exhust systems that can have asbos put on them can you believe or engines with wrong numbers on not matching v.5 it all depeneds but like has being said surley it cannot be illegal to tune? next thing you know well have to apply for a tuning permision slip or som sort of bo$%cks like they do planning for building work what is the planet coming to i agree with alot of things but this is abit daft besides the people they trying to get at i.e the chavy idiots dont even have the funds to tune they opt for go faster stripes now thats a defo illigal mod call in the fasion police o and another thing ive always decared any mods to insurence making them legal in my book just my little rant there guys lol
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Visual inspection
    but is it illegal to remap a car ?
    It wording they use ,as you can see its a visual inspection , you cant see remaps.
    scott b's Avatar
    1,254
    spoke to a mate who is a MOT tester, they have had nothing come through yet about the change in the MOTs
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    No i know
    i am a tester but its coming i can assure you .
    scott b's Avatar
    1,254
    dooh, but he read through that link and said he would still pass HID's as long as the aim was ok
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    4.1.4. Compliance with requirements ( a ).
    Visual inspection and by operation.
    (a) Lamp, emitted colour, position or intensity not in accordance with the requirements ( a ). (b) Products on lens or light source which obviously reduce light intensity or change emitted colour. (c) Light source and lamp not compatible
    The piece that makes it a fail so far
    its (c) Light source and lamp not compatible
    Its also a visual inspection and to be judged by operation
    which is where the problem will arrive as halogen lighting comes on totally different to HID lighting as we all know .
    scott b's Avatar
    1,254
    light source and lamp not compatible, now that could be seen as say the wrong bulb ie to higher wattage perhaps?
    again it is a grey area
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Visual inspection and by operation ,
    theres no grey area there as i explained already .
    Aug 2009
    833
    it will never come through, HIDs maybe ecu tuning never.
  28. #27
    27,115
    Spoke to my respected tuning guy, ecu tuning he is very adamant wont happen, his comments to be exact
    "There is absolutely no way that they can read every car to ascertain whether the ECU is stock or not as many Fords, Vauxhalls, Porsches etc etc cannot be read without taking the ECU out and using a BDM machine. I can't see VOSA investing in such equipment as the manufacturer will not make the information public knowledge."
    Personally I have to agree, will make mots longer which may close allot down unless they make them more expensive, which will then alienate us drivers even more.
  29. #28
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Quote Originally Posted by Nutkin View Post
    Its coming in thats a fact
    but as i already said myself
    theres no way they will read or find remapped ECUs
    tuning boxes yes unless well hidden
    HIDs retro fit are an easy spot so will be failed
    On a personal level im still of the opinion that if retro fit hids are in projector light units and set up with in aim limits there should be no issue ,
    but there you go .
  30. #29
    Aug 2009
    833
    but there you go .
    It won't come in, ECU tuning has nothing illegal on it. If you get a tuning box and plug it in, declare to insurance then there is nothing wrong with that. you are not harming anyone at all, it has no place being on the MOT.
  31. #30
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Bloody Hell its coming in its already been passed as an EU directive
    if you had bothered reading the link or my posts,
    i also said it will not be traceable as a map in my opinion
    only as an aditional box thats visible
    if your not happy with MOT regulations Dont run a car
    and lots of things have no place being in an MOT as with so many things in life but tuff
    your also taking the word illegal as a law statement its not with an MOT its about rules
    the word illegal has more than one meaning
    Example
    1. Prohibited by law.
    2. Prohibited by official rules
    in relation to MOTs it has in this case nothing to do with the law its about rules
    theres nothing Me You or Anyone else can do about it is there?
    well there is you can run around without a test but that would be illegal law wise .
  32. #31
    Mar 2008
    Dorset
    13,856
    Looks like we're all gonna have to become a bit handy at removing and refitting HID kits
  33. #32
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Personally mate
    and i dont want to get flamed for this
    but all you have to do is swap out the bulb and plug the halogen back in for test
    theres nothing saying your not allowed to fit unused ballasts under your bonnet .
  34. #33
    Mar 2008
    Dorset
    13,856
    Exactly, as long as it passes on the day the job's a good 'un.
