Hi, i was just wondering if anyone knows the process to Remove/Replace the passenger wing. After The misses decided to ding my car in the snow. The car is a 2004 Saloon. Thanks in advance.
Ive finally finished the wing today. Basically it went in this order...
:Remove Headlights.
:Remove front Bumper.
:Remove Arch Liner.
:Remove Side Skirt.
:Remove Wing Bolts in engine bay
:Remove Wing bolts from inside door
:Remove Wing Bolts form inside wheel arch.
Then put everything back on. Easier said than done!!
Looks better than it did. and probably cost me a bit less than it would have.
