Results 1 to 9 of 9
    Gavlar's Avatar
    Sep 2010
    Maidstone, Kent
    312
    Engine squeaking when cold
    Not sure if this is a silly question but my 1.8t squeaks when the engine is cold. What is this and what can I do to fix it?
    Many thanks
    Mar 2007
    salford gtr manchester
    564
    hi mate the most likely cause of squeeks on a cold engine is one of the belt tensioners . i had this on mine so i changed the alternator one way pulley that never worked but it turned out to be the auxhilary belt tensioner bearing changed this and the sqeek went away
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    just spray a tiny bit of wd40 on the belts if the squek goes away replace belt and maybe tensioner, thats if it is the problem, but that would be the first thing to look at
    Gavlar's Avatar
    Sep 2010
    Maidstone, Kent
    312
    Would that not have been done when cam belt was done?
    Mar 2007
    564
    if you did not ask the garage to replace auxhilary belt components its very unlikely that they would of replaced them
    Gavlar's Avatar
    Sep 2010
    Maidstone, Kent
    312
    Ah ok. Is this gonna cost alot to fix?
    Mar 2007
    564
    i dont know the costs for your model . but for my 1.9 tdi the alternator one way pulley was Ł34.00 and the auxhilary belt tensioner was Ł 36.00 from GSF i fitted them myself if you are taking it to a garage i would have them fit both at the same time
    Gavlar's Avatar
    Sep 2010
    Maidstone, Kent
    312
    Are they hard to fit yourself?
    kujo's Avatar
    Jan 2011
    Southampton
    17
    I'd be interested to know if they are hard to fit as well as I need to do this.
    Kev
    A4 Avant 1.9tdi Sport
    Mods to come: Black Grill. Black Roof Rails, Dual Exhaust....
