Results 1 to 16 of 16
Thread: Tow hitch
    alcoholic pervert
    Nov 2008
    Chalford - the Cotswolds.
    181
    Tow hitch
    Anyone fitted a tow hitch? Not exactly a performance mod I know… but having just smashed a light while loading the boot with logs I think a tow hitch and trailer is the way to go for me.
    (I'm becoming more like my Dad every day)
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    yes, fit them day in, day out, fit towbars, dual controls reversing sensors for a living
    alcoholic pervert
    Nov 2008
    181
    Nice one. So what's involved? Years ago you could get kits to fit yourself from halfords - guessing it's not that simple any more...
    What should I expect to pay?
    scott b's Avatar
    1,254
    what area are you?
    we usally charge around Ł185 + vat to supply and fit standard towbar with single electrics
    you can buy the parts yourself from the likes of ebay, if your handy with spanners and ok with electric then its do able yourself, as long as you have the right tools and dont mind pulling your car to bits and have a spare day then you'll have no problems, but they are an involved one to, bearing in mind its, bumper off, lower exhaust, remove rear panels in the boot, boot floor covering and rear sub/amp, the reason you need to remove the interior parts is to get to the wiring and gain access to the nuts that hold part of the bumper on
    alcoholic pervert
    Nov 2008
    181
    Does sound like a days work for the likes of me. And I'll probably break a few bits in the process.
    I'm too far south of you - Wilts/Glos. I'll ask around locally I guess.
    WEST MIDLANDS
    22
    Hi, I fitted a detachable towar myself a few months ago to my 2003 (B6) A4 convertible. brought a new one off ebay for Ł140. it came with easy to follow fitting instructions for the bar and electrics. It took me less than a day to fit. Removing the rear bumper and getting to the bolts around the exhaust system was the trickiest bit but only because Ive never dont one before.
    I went for the detachable so to not spoil the look of the car. when the towbar is folded away you cant see it (or the electrics) at all.
    The swan neck detaches and is stored in your spare wheel well and the electrics fold neatly under (inside the bumper) totally hidden.
    well recommended in my opinion.
    Let me know if you need any advice.
    alcoholic pervert
    Nov 2008
    181
    Detachable sounds good. I like the idea of not seeing it when I don't need it. Ł140 sounds good too.
    Is it as robust as a fixed one? Are there limits to what you can tow in comparison to a fixed one?
    scott b's Avatar
    1,254
    there all designed and manufactured to handle the max towing limit of the car, only dis advantage with the detachable is that you cant have a bike rack on at the same time as towing and if you decide to tow a caravan then you cant fit a stabilizer to it either (you would need the dearer alco hitch option)
    but how often do you tow/plan to tow, just that if you where to go for a towsure towbar for example, the neck is held on with just 2 bolts, so not exacly a big job to remove the neck
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,579
    Mines the Westfalia detachable.... completely hidden when not in use, not cheap though, was Ł400 fully fitted including an extra 12V socket in the boot, having seen it done, it's not that difficult, but a little unnerving watching the back of the car come off...
    removed: slotted in (10secs later):
    and views under the bumper:
    LostBok/BahnStormer77
    scott b's Avatar
    1,254
    the westfalia one is oem
    WEST MIDLANDS
    22
    Mines a westfalia detachable also. Check out eBay at the moment, item no. 290380038587. Ł160 plus Ł8 p&p.
    Def the best option in my opinion. Fixed towbars are more practical but ugly and spoil the look of the car, especially a convertible.
    WEST MIDLANDS
    22
    I fitted mine especialy to tow a family caravan (with alco hitch) but we had our caravan knicked. So now i use it to tow a camping trailer with roof bars fitted for the mountain bikes or roof box. I got best of both worlds now, a convertible with family practicality! I can tow and carry bikes etc.
    Avant4me's Avatar
    The're Graphite not black!!
    Mar 2010
    Bristol
    257
    Been thinking about these for a while. Do you have to butcher the electrics or since the car had a towbar as an optional extra, is the electric pack a plug in job?
    Official Fan Club member No 001!!
    WEST MIDLANDS
    22
    not sure about plug in type? mine is a convertible, no plug for towing electrics, not that i know to anyway.
    I removed panels in boot (right hand side) then I used a curcuit tester to find each correct wire and then used blue scotchlock connectors (supplied with towbar), so didnt need to cut any wires.
    scott b's Avatar
    1,254
    Quote Originally Posted by Avant4me View Post
    im pretty sure you can get a dedicated wiring kit, just a case of fitting a lom inbetween the car loom and the rear lights, then earthing and powering up the relay box
    BahnStormer
    Feb 2009
    Surrey
    2,579
    Mine has an extra piggy back in the fusebox and extra wiring running the length of the car through to the boot: I checked that was just part of the tow bar electrics and NOT because I asked to get an extra 12V socket in the boot.
    I think the Westfalia will fit to conververtibles, but NOT the S4's.
