Chris NottBadger5
    Mar 2009
    53
    Fitting Cruise to B6 Cab - SCM part numbers
    Hi Folks,
    There is a lot of information out there about fitting cruise to B6's, and I'm fairly confident of completing the modification this weekend. I just have one question which I cannot find a definite answer to:
    What version/part number of the steering-wheel control module is required for activating cruise?
    I've read that there is a possibility that the control module fitted to Cab's may already have the cruise option and it just needs to be coded with Vag-Com. Can anyone enlighten me as to the correct part numbers? I read somewhere it is possible to test if the module is compatible by trying to code it to cruise and seeing what errors are produced, this sounds a little risky, unless someone has an idiot's guide...
    If the control module is compatible, all that's required is the stalk, the facia panel and coding of the steering-wheel control module and the ECU? Right? Sounds too good to be true as all that can be obtained for under 40!
    Thanks as always,
    Seb.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,429
    8E0 953 549 R
    8E0 953 549 Q
    if you have MFSW then you only need is
    So all you need is: Switch - 4E0953521B4PK - 26.12+vat
    2 screws - N90906802 - 0.09p each +vat
    Lower Cowl - 8E0953512P 6PS* (for near black trim*) - 25.59 + vat
    if you have VCDS you can check what SCM you have fitted
    Mar 2009
    53
    Thanks for the info, I just found this great guide on another forum: https://docs.google.com/fileview?id=...1NjEz&hl=en_GB
    Contains step-by-step with instructions. Perfect!
