Sky InsuranceEM Tuning
    Dec 2004
    Wales
    Variable service distance?
    Just spoke to my local Audi dealer after checking the distance left to service (which said 12400 miles), which is obviously wrong as I've only done a couple of hundred from new. He said the figure will work it's way down to zero as the car studies your driving characteristics, and then determines the distance required before service is needed, which can be anything up to 25000 miles.
    What's all that about?
    In other words, does anyone know any more about this?
    cheers.
    chris
    imported_Macduff
    Re: Variable service distance?
    It will go up as well. Ours started at under 17k but then went up to 18-19k.
    It bases the distance to service on
    - type of journeys
    - condition of oil (using a couple of sensors in the sump)
    - driving style
    Not really new technology as BMW have had it for years. I believe the minimum distance between services is 9k and the max is around 20k (petrol) or 30k (diesel)
    HTH
    Dave
