Monster MotorsportVolks Autos
Results 1 to 7 of 7
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Squeaking Brakes - Help and advice please......
    Hi - I have fairly new pads and discs all round but I now have an annoying squeal when the brake pedal is applied.
    What are the normal symptoms and remedies for this?
    It's really beginning to pi*s me off when pulling up at lights followed by this bloody noise!!
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,703
    Is it more than just salt and crud on the pads?
    Did you put plenty of coppaslip on the back of the pads? And are they oem?
    Mar 2009
    Somerset, UK
    148
    I have the same problem with mine as I changed all the pads and discs recently but either the squealing is reducing with use or I'm getting used to it, I didn't fit OEM stuff. The squealing can be caused by many factors including pad material, I think the higher the metallic content the noisier they can be.
    But it's nowhere near as bad as when I fitted some fast road spec mintex pads with black diamond grooved and drilled discs to a pug 309 gti I had years ago, no that sounded like a touring car when braking, they didn't last long before I changed the pads back to standard.
    2004 A4 1.8T S-line 218
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Yes, non oem and Mintex!! They are goin in the bin!
    Mar 2009
    Somerset, UK
    148
    Quote Originally Posted by CHRIS555 View Post
    Did you get them from Brakes International? as I got mine from there and they were non OEM discs and mintex pads.
    Have your front pads got a strange bracket on the outside pad (closest to wheel), I found I had to bend them out slightly so the pad retaining spring could locate under it, as when I first fitted them i found the spring was putting slight pressure on the pad via the bracket and the pad was slightly rubbing on the brake disk after taking your foot off the brake, since I did that the squealing has virtually stopped, infact today I only noticed it once.
    Sep 2010
    167
    I tend to find ferrodo pads are bad for squealing, we used to fit them at work and were getting so many come backs we decided to fit bosch pads, massive difference noticed, fitted oem pads too which seem to be fine most of the time.
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Quote Originally Posted by quattro tony View Post
    See its all strange as we pretty much fit ferodo pads on everything and dont have any back.
