Well not long back from my mechanic! He is a top geezer and I have been there all day pottering around the unit as he worked on the motor.
Firstly we took the front end off (well hung it down a bit) to check the timing. Timing is SPOT on he said, no problems there.
Then we changed the alternator pulley/clutch. Definetly at fault comparing old one to new one so glad that was changed.
The tensioner part that I show in the video is suppose to move about like that, this is normal behaviour.
Front end put back, all hoses checked and only issue found was the intercooler hose needed nipping up slightly.
Engine mount then changed for new one and plugged back in.
New Fuel Filter fitted - the pipes going to the filter were a bit mangled from previous garage fitting stupid clips that have chewed up the pipework so just nipped off those bits so it was clean just incase any air was getting in.
We then started the car back up. No problems with rough running as expected as engine been warm. But you can see the engine rock about and move about a lot randomly.
My mechanics assessment is we could have early signs of DMF failure
Bit of a noice from the back of the engine etc. He said that can cause the random rocking of the engine too.
We couldn't clean the EGR as its a bit of a job as pipes in the way and needs a good hour to take off and clean properly. But I will get this done in about a week time when I am getting my braided brake lines fitted.
Then we fitted all new disks and pads all round!
Not a cheap day for me
Not good when I have already had my Leon Cupra R uprated clutch and back plate (£505) and DMF and labour (£450) fitted just before Christmas with him
Its been an expensive month!!!
I have yet to test the car in the morning but will do.
Mechanic also cleared the mount error from VAG com and check measuring blocks and everything looked spot on.
He has suggested some injector cleaner as well which I will get tomorrow.
There we go.......DMF/Clutch AINT gonna be cheap - He said basically to keep an eye on it and wait til things get worse before doing much else past the EGR clean.
Argghhhh!!!!!!
