Badger5AH Fabrications
    Nov 2010
    Airbag light and Fuel Gauge FAULT!!!
    The Engine was leaking oil, so were trying to change the Crank Shaft Seal, as the mechanic was doing something to be able to open the bolt, I have seen and electrical contact sort of elektrical spark from the cables ( not sure but I think so), then when we run the engine the Fuel Gauge was not working at all and the Airbag light came up. Could it be the cable, or fuses? Everything was working fine before.
    Can somebody help me urgently? Very much appriciated!
    slepy's Avatar
    Sep 2009
    Sheffield
    1,129
    You need to scan it with vag-com to see what error it shows.
Tags for this Thread
