Monster MotorsportEM Tuning
Results 1 to 11 of 11
    Sep 2005
    Staffordshire, UK
    455
    Cool Buying Guide....
    Hi guys,
    I have been looking for a dark A4 Avant 2004 Sline for ages and eventually I have found one.
    54 plate....checked the service history with the dealers etc etc and it all pans out. Had the cambelt done at 97k and its on 99k.
    Anything I should be looking out for, it has the alcantra interior, one of the dealers said the rear and front window motors were changed recently which seemed a bit odd Are they likely to go?
    How do I know if its got a Bose sound system? Its got a single CD front and think it has a changer in the glove compartment?
    Any help or tips appreciated, hope to pick it up Saturday, snow permitting!
    It also seems to have the Avus S4 wheels on too!
    No prizes for guessing which one im seeing if you use autotrader! LOL!
    Rich
    Sep 2005
    Staffordshire, UK
    455
    anyone?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,751
    I don't know much about the 1.8T..... I've never heard of window motors being problematic.
    If it has Bose then it will have small badges on the speaker grilles saying so, and will also display Bose in the stereo when you turn it on.
    The Avus wheels are a nice touch if they're genuines, which I imagine they are.
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    It's crucial that these engines have had regular oil changes - if it hasn't had a recent one get them to do it.
    As a whole they are a very good solid car so I guess looking at things like service history and wear and tear is the best advice.
    Same as above - never heard of the windows being an issue so it probably just had a niggle which has been rectified.
    Oct 2010
    Hampshire
    286
    Big expenses will be,
    Timing belt - already done, check waterpump was done at the same time as these fail
    Clutch - If it hasn't had one then it could be around the corner and this is a large cost
    Plenum chamber drains - check there is no water below battery and that drains are clear or removed - see my other posts if not sure. If there is water in there then beware.
    1.8T's have minor niggles but nothing too expensive imo. Coil packs, MAF, Diverter valve, thermostat, temp sender all can fail at this mileage. Ask for a scan of fault codes if its from a garage to ensure there are none. As mentioned check service history. Standard intervals 10k and longlife intervals up around 15k i think. If it has been on long life then you might want to consider cleaning the oil pick up pipe as they are more common to block. I stick to oil changes at 10k/ 1 year max on my S3. If its never had the gearbox oil changed then its about the mileage that would improve things noticeably.
    Window motors failing is a bit of weird one. Might be worth finding out more about this if you can.
    Sep 2005
    Staffordshire, UK
    455
    Thanks for the replies guys!
    Its a 1.9tdi! Hehe! Not a petrol!
    It wasn't the window mechs but the wiper mechs that were changed. Front and rear.
    It has the concert stereo in it single CD - no sign of Bose on it Sounds ok tho!
    Has half alcantra interior which is lovely and the car is pretty much spotless.
    Is the glove compartment suppose to be so stiff and have to really pull on it to open it? Just seems like it has soft opening.
    We bought it 7500 and mileage all checks out as I rang the dealers.
    Has had cambelt and water pump done 1000 miles ago
    I will VAG com it today.
    Front bulb went on the way home! LOL! so need to get that sorted.
    Could I upgrade the stereo to anything audi genuine easily?????
    Thanks all, we love the motor so far!
    Pity its only doing 39mpg average on the dual carriage ways last night coming home, i hoped it would do a bit more!!!
    Rich
    Sep 2005
    Staffordshire, UK
    455
    Oh yeah, and is the middle button in the remote suppose to open the boot
    will89's Avatar
    Jul 2010
    362
    Quote Originally Posted by Funkyfin2000 View Post
    Yeah hold it down for a couple seconds and you'll hear it 'pop'
    Sep 2005
    Staffordshire, UK
    455
    ooo thanks dude, will check! :D
    Mar 2008
    Dorset
    13,751
    It only clicks the boot open though, rather than an electric opening as such - a bit pointless imo.
    The stiff glovebox will be as a result of the damper seizing up. I would make this the first job you do as it WILL break the glovebox hinge very soon! See here: A4 owners - do this today and save yourself over 150!
    Both wiper mechanisms being replaced isn't unexpected. The front wiper mechanism is known for going stiff over time, and if not rectified will burn the motor out. Just make sure the mechanism was replaced or freed up at the same time. The washer pipe can split in the tailgate, resulting in a knackered rear wiper motor which is probably whats happened.
    Sounds a nice car though, now go do the glovebox damper!
    Sep 2005
    Staffordshire, UK
    455
    Thanks JAmes, top tip, will take a look at the glove box asap.
    I guess I can do remedial action to help it rather than completly strip it down
    Will check the guide out tho!
