EM TuningMonster Motorsport
Results 1 to 33 of 33
    Aug 2009
    833
    A4 2004 1.8 TQS - What size are the discs
    Need to order some and have a choice of 2
    288mm
    312mm
    The 312mm say cabriolet option. So im assuming 288mm and its raining outside so dont really want to go take a wheel off and check.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    only the big engined versions got the 312s .
    288 all the way mate
    Aug 2009
    833
    Good just ordered all 4 corners pads and disks for 140 delivered from brakeparts after reading many glowing reviews on several forums.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Are we 100% sure that quattro models don't come with 312mm discs?
    Apr 2004
    12,520
    I spose I could double check etka etc if you like ?, but i am 99.9% on it. It's the larger engined ones that get them, 2.5Tdi s etc etc
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    i second quattrojames ( hi mate, been a while ) as far as i was aware the quatts had the bigger discs for the extra weight etc etc
    LOTS DONE, LOTS SPENT !!!!
    Apr 2004
    12,520
    B5's deffo don't
    I will check and start making my humble pie, in case i need to eat it,lol
    Aug 2009
    833
    acording to the shop on cabs have the 312mm discs, and also it said the 288 were the ones with the pads with wear sensors and i defo have wear sensors.
    What do i need as regards to tools? Someone said something about an Allen bolt head for the caliper removal?
    Not sure i have one of these someone confirm sizes?
    Apr 2004
    12,520
    The PR code is
    PR 1Lt and 1LF for 312mm discs, if those codes show in your service book etc, i am pie munching
    PR 1LZ,1LB and 1LF are 288's
    GULP!!!
    Aug 2009
    833
    Quote Originally Posted by Byzan A4 View Post
    The PR code is
    GULP!!!
    eugh* goes to find his book*
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    lmfao, if youve already made it byz, if im wrong ill pop over and just eat yours, save me makin one lol.
    as for the above comment on the 288mm one having the sensors, i have a cab with the 312mm disc which also have the sensors on them.
    you will need a 7mm alan key ( which you DONT get in a set ) you only get a 5mm, 6mm and a 8mm, no 7!!!
    Aug 2009
    833
    Dam you I have 1LT
    Aug 2009
    833
    Im assuming its just written amoungst all the codes on the sticker on ym service book.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    result, at least you can order the correct ones and not have the hassel of removing the old ones and then find out !!
    and byzan can now dig into his pie !!! lmfao
    Apr 2004
    12,520
    Yarp
    Aug 2009
    833
    I'VE ALREADY ORDERED THE WRONG ONES DAMMIT!!!!
    I want a slice of that pie.
    Apr 2004
    12,520
    Quote Originally Posted by Nutkin View Post
    Dam you I have 1LT
    Aug 2009
    833
    This shall not be forgotten... I demand Satisfaction.
    Mar 2008
    Dorset
    13,856
    I'm just sorry I didn't post this 11 minutes earlier!
    Nutkin I'm sure if you ring them first thing you can get this order amended at no cost to you.
    Aug 2009
    833
    I wont be able to phone them in the morning as ill be traveling to south wales with my duelling pistols!
    Apr 2004
    12,520
    its ok i won't be going anywhere, my A4 is broken as always.
    Aug 2009
    833
    All I can say is I want some of that pie!!!
    Apr 2004
    12,520
    what can i say, i am human, and i error'd.
    SORRY !!
    I don't suppose it matters it was meant with the best intentions to help. My information was incorrect as I too was told the same as you ( Cabs 312 and larger engines etc) when i was doing the 312 conversion many moons ago.
    I will be more careful to not post withot irrefutable evidence from now on.
    Aug 2009
    833
    SORRY !!
    Pfft its fine :P Im sure it will sort itself out i'm just fed up with all the beeping and lights on the dash. got a sidelight bulb out and the air bag indicators on due to passenger seat airbag, not sure what to do about that one.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    dont be daft byz, were all here to help ! we dont all get it right all the time, i wasnt 100%, was only voicing my opinion, i was more than ready to delv into that pie myself !
    Aug 2009
    833
    Its fine no harm done tbf only 60 quid on fronts and im sure theyll swap it tomoz
  28. #27
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Yep, 312's on my convertible
  29. #28
    Mar 2008
    Dorset
    13,856
    If not then I'm sure Mark will buy them....
  30. #29
    Apr 2004
    12,520
    Yeah, why not...LOL
    Will work well with my RS4 Calipers.....he he he
  31. #30
    Avant4me's Avatar
    The're Graphite not black!!
    Mar 2010
    Bristol
    257
    I am surprised by this as is did lots of research when looking into the 312 upgrade, didn't do it in the end as i couldn't find second hand carriers and wasn't prepared to buy new. Even EBC themselves say that all the 1.8 and 1.9 engines use 288mm discs.
  32. #31
    Apr 2004
    12,520
    Quote Originally Posted by Avant4me View Post
    Yup that was my info too..
    I hope Nutkin has sorted it now.
  33. #32
    Higgsy's Avatar
    Hard To Spin
    Jockland
    95
    i think ive got 312mms on my 190 qTS, prob no help but thats what it says :-)
  34. #33
    Aug 2009
    833
    Order came today, more than happy. The guy on the phone was extremely helpful and just canceled one order and made a new one with me there and then.
    Brakes, brake discs, brake pads, brake calipers - Brakes International Shop
    Bits came today and the front pads are mintex oem, disks are oem packed too. Cheap as chips and more than worth it. better than no name ebay crap imo
