Page 1 of 4 1234 LastLast
Results 1 to 40 of 148
Like Tree1Likes
Thread: Plenum Chamber Drain Grommets - Every A4 B6 owner is affected by this common fault
    Oct 2010
    Hampshire
    294
    Just writing this as I remain suprised that there is not an obvious sticky thread for this design fault and I continue to read posts about people having problems when it rains.
    Surely every A4 B6 owner has now removed the grommets in the bottom of the plenum chamber?
    There are rubber grommets below battery on the left and below the brake servo on the right fill with crap and dont let water escape from the car.
    If you haven't removed these it is purely a matter of time before your car fails in an expensive (water in ECU, HVAC, engine) or dangerous (brake servo failure) way.
    I dont think this common fault is highlighted enough in this forum as the consequences of not sorting can cost many thousands.
    How to fix the problem here
    (for a passat but identical problem)
    or
    ### UPDATED LINK Interior leaking | veedoubleu dot com ###
    Take your car to a dealer and they will fix it for free.
    Really hope this saves a few people from disaster.
    Paul
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    You're right in that it is a fairly common problem, but I think the worst most people see is a wet carpet, with the expensive brake servo and ecu problems being thankfully rare.
    I'd second the advice in the article though and remove. clean and replace the drains rather than leave them out.
    simon.m's Avatar
    Oct 2009
    2,746
    will audi really fix it for free and if so what do you ask them to do
    Oct 2010
    Hampshire
    294
    Ask Audi if your car has had the 'Plenum Chamber Recall'. Audi used to remove the grommets and not necessarily tell the owner, now I think it is an official recall. Give them a call.
    Only other tips if you do it yourself are the consequences of removing the battery. Make sure you have your radio code. Also if your key doesn't lock/unlock the car afterwards, put it into the ignition, turn to position 2, and press lock and unlock together.
    simon.m's Avatar
    Oct 2009
    2,746
    think ill call them thanks mate
    Mar 2008
    Dorset
    13,856
    The internal memory in the radio should hold the code for a couple of hours.
    Also the ESP light might come for the first quarter of a mile or so afterwards until the sensors adjust themselves.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    iv cleaned my ones out, i do it every autumn, a good black on an air line from under the car is normally the easy way to do it, i did think about just pulling them out, but thinking about it i decided not to as to stop dirt etc etc going up there and clogging it that way,
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    This effects loads of models not just A4s and not just B6s its very common but easily fixed
    you dont even need too take the battery out you can get your hand under the panel from the engine bay and pull it out from there , sometimes removing the exspansion tank and moving it too one side helps this gives your arm more room too .
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    i wouldnt remove them completely, but i trimmed a bit off the bottom of mine so its open all the time.
    Hopefully that will stop the silt building up in the holes. Its always worth checking them every 6 months to be sure though.
    TD5 Land Rover Defender build
    simon.m's Avatar
    Oct 2009
    2,746
    so just called audi they run a check on my car and said mine was not one of the ones with this problem and it was only certon chassisy numbered cars that had it and mine was not one of them and in the last 6 mths audi have started to send out letters to ppl who have the cars that need a re call
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    What year is your car Simon? I'm assuming the problem was mostly on the earlier b6's? I was at my local audi this morning and I would of asked them about mine if I had read this post before hand.
    simon.m's Avatar
    Oct 2009
    2,746
    well mines a 52 plate mate and i asked if it was just the ones befor mine they said no it was certain chassisy numbered cars if that makes sence.
    Oct 2010
    Hampshire
    294
    To be sure I would assume it is every B6 and get yours checked one way or another.
    Whether you remove or regularly clean is your call. All the silt and dirt that washes down your windscreen goes through the plenum chamber so I am not worried about two holes allowing a small amount of dirt upwards through the holes so I chose to remove the grommets and this is the Audi 'fix'. My S3 just has two holes to the outside world at either end of the chamber.
    I'm glad this thread is helping create awareness of the problem. I wish I had known about it before owning the car for a year. One of mine below the servo was totally blocked.
    Paul
    simon.m's Avatar
    Oct 2009
    2,746
    yeah i will keep an eye on mine just to be safe iv had the car just over a year now and have never seen any warter in there at all always seems very dry. but like i say it will not kill me or any one to have a look every time you wash the car to be safe. thanks paul
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Ive seen water in 03 plate cars so just pull the bungs its done and no need to worry then
    Oct 2009
    Hull
    1,440
    did mine yesterday while i had the battery out! easy enough and there was plenty of crap in the grommets!! mines also a 52 plate simon and ive seen water in there before hence taking them out!!
    simon.m's Avatar
    Oct 2009
    2,746
    well i can only go buy what audi have told me and that was certain chassisy numbered cars not reg/year mate i dont now how they can say this mind but they are 100% sure there where some chassisy numbers that have this problem and some that dont go figer a i will still keep an eye on mine like i said and the first time i see it i will take it to them to fix. but as of yet its always been dry. luckly
    Oct 2010
    Hampshire
    294
    Mine was a 52 plate. The older the car the more dirt they will have collected!
    I think Audi will only recall ones below a certain age and that is why your chassis was not listed.
    simon.m's Avatar
    Oct 2009
    2,746
    i can only go buy what i was told mate some chassis had this problem and otheres did not
    Oct 2010
    Hampshire
    294
    Quote Originally Posted by simon2004 View Post
    With respect I disagree, you can get under the bonnet yourself and have a look or you can take the car to the garage and ask them to look at it for you.
    Given the consequences I dont see why you would assume everything is ok. Ignore Audi, they are wrong.
    Oct 2009
    Kent
    314
    Hi guys,
    I too phoned audi (east kent) today & they told me its only certain chassis numbers that this affects but i gave them mine and my fathers but they said they were not included, so thats 3 different cars all different years, so which ones are getting the recall, seems a bit like they dont want to do them to me
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Mine was dry on a 51 plate but having seen so many i pulled them just to be sure its not worth the risk and i dont see your issue "just do it "
    BASS 666's Avatar
    BMW aye right dead on..
    Sep 2010
    belfast
    463
    no one has the right chassis number..
    2002 1.9 tdi 130ish brake a4. full reiger body kit, 19 inch rs6 avant rims, eibach springs, home made grill, full leather interior, centre arm rest, quad powerflow exausts, a few engine mods, chrome door mirrors, aero wipers, s line door blades.
    "Stick a V8 in it!"
    15,370
    The exact same issue plagued B5 models throughout their life. Your car WILL be affected by this.
    simon.m's Avatar
    Oct 2009
    2,746
    Quote Originally Posted by pj123 View Post
    i do keep an eye on mine and its always been dry if i see it filling up it will be the first thing i do but in the year or so iv had my car its been ok so fingers crosed it will stay that way
    simon.m's Avatar
    Oct 2009
    2,746
    Quote Originally Posted by paul20v View Post
    are they easy to get at mate and just pull them out also what are they there for if they just make problems
  28. #27
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    they are rubber gromets with holes in them to let the water out but they can block up. i have mine out.
  29. #28
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    1 under your battery 1 under your servo.
  30. #29
    simon.m's Avatar
    Oct 2009
    2,746
    thanks for the where they are bass666 i new what they would look like thought :-) just was not sure where and best way to get at them
  31. #30
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,268
    I called Audi and they said mine was due a recall so in it went. They took 45 mins to do it and when they came to give me the car back they had done a full vehicle inspection. 5 mins to remove the bungs and 40 mins looking for work! They certainly never removed the battery so all i can presume is that they removed the bungs all together. I only called them because there was around 1 inch of water sat in there no damage though. My car is a 2001 and was registered 10/01.
  32. #31
    Oct 2010
    Hampshire
    294
    If you have a car lift then you can reach up and pull them out or clean them out from below. If you dont have this kind of access then follow the how to guide at the top of this thread.
  33. #32
    simon.m's Avatar
    Oct 2009
    2,746
    thanks pj123
  34. #33
    Oct 2010
    Hampshire
    294
    Not a problem, hope this saves you from disaster!
  35. #34
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    thanks pj123
    I had already told you how to remove them from under the bonnet.
  36. #35
    simon.m's Avatar
    Oct 2009
    2,746
    yes you did but you did not say where they where you said just get your hand under the panel from the engine bay and pull it out from there so me being well me asked where they where so i dont have to take the hole lot out if i did not need to ;-)
  37. #36
    Jul 2007
    770
    Had this problem on a B5 some years ago and worked out that you can feel for the holes with a long bottle brush and push through the blockages then clean out with a hose until the water runs clear out of the drains.I dont think the bungs came out but I regularly checked the chamber for the next 5 years and vacuumed any litter out and no more problems.So far the replacement B6 has not been any bother but I still keep it cleaned out because I have to park under trees overhanging the drive,Obviously Audi Bung Design Dept needs to learn from others if they have not revised the item yet
  38. #37
    deanski's Avatar
    wax on, wax off
    May 2010
    Lancashire
    374
    audi recalled mine and did the fix. mines a 2001.
  39. #38
    Mar 2009
    470
    Quote Originally Posted by deanski View Post
    Was the recall done recently?
    Should those affected be expecting some correspondence from Audi regarding this?
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
  40. #39
    183
    did you actually get a letter after 9 years? Or did you ask in audi?
  41. #40
    markA4tdi
    Darlington North East
    105
    First of all a massive thanks for reminding me and other users of this known problem, i had a few spare mins this am and thought i,d check this again, and guess what ! the water level was about 3 inches in there! ....now mine did get recalled late last year it was a recall notice i posted on here 51B7 was audis recall number, they did the unblocking of the so called plenum chamber, all tickety boo... now considering ive only done approx 3 thousand miles since then, i was surprised to see how much crap/silt/dirt was in the actual rubber bungs and area around the battery and servo unit, so needless to say i have removed them all together, hopefully a final soloution to the problem. As said remove the battery it is much easier to remove the bungs with the battery out, dont worry your radio didnt need the code and yep the traction light does illuminate as already posted and like others say, i expect this to go out after a short drive.
    so a massive thanks to you! saved a potential big bill!
    by the way mine is a 2002
    cheers!
