Results 1 to 32 of 32
Like Tree8Likes
  • 3 Post By quattrojames
  • 1 Post By fourcircle
  • 1 Post By S90GAV
  • 1 Post By S3 GAZ
  • 2 Post By quattrojames
Thread: Slow wiper mechanism repair
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,712
    There are guides for a RHD B5 and a LHD B6 so I thought I'd throw together a few words for the RHD B6.
    The slow wiper problem seems to be fairly widespread in the A4's, and is caused by the spindles slowly seizing tight in the sleeves of the mounting mechanism. The mechanism can be replaced for �70 ish or stripped down and regreased within a couple of hours.
    You need some emery cloth or similar, and I used Coppaslip grease to regrease them. Apologies for the picture quality, I just grabbed shots as I went.
    It would probably be sensible to disconnect the battery while you do this.
    First off I marked where the wipers sat on the screen with some tape, to ensure they went back in the same place.
    A little pick or something to remove the end caps on the wiper arms.
    A 17mm socket to remove the mounting nut.
    Getting the arms off can be tricky, don't twist them on the spindle as you may damage the splines. Wiggle them from 12 to 6 O'clock and they 'should' come off. If they're really on there then a tool like this will be required for about �10.
    Once they're both off you're left with this: If you've got a battery cover fitted then you'll need to remove that. Start by pulling the rubber seal off;
    The whole tray can then be removed:
    The plastic scuttle cover at the base of the screen needs to come off next, there are three clips as shown below (ALL mine were missing ) Getting this off is pretty difficult, and I broke mine. When I get a replacement I will update with the part number as it's only about �15. It sits in a small few mm deep groove in the base of the screen, and mine had 7 years of crud holding it in place. Some users have had good results using warm soapy water first to help remove the cover.
    Offside.
    Centre.
    Nearside.
    This is mine coming out:
    And the broken bit left behind, you can see where it has broken off leaving part of it in the channel.
    Next step is then to remove the ECU cover, requires a torx driver.
    The ECU clips out and can be folded out the way.
    By now you should be able to clearly see the three 10mm bolts holding the whole mechanism in, remove all three.
    The mechanism will now be loose, but trapped in. The base of the ECU box can be undone and shifted out the way enough to allow you to twist the mechanism out. Getting this out took me a few minutes, and you might find more flexibility by popping off a couple of the knuckles in the mechanism with a prybar. My hands were a bit grubby by this point so I've not really got any good photo's - but it's fairly self explanatory.
    Once the mechanism is out you need to disconnect the motor. The plug has a catch on the underside which needs to be slid in the direction of the arrow to release it.
    Once the mechanism is out you're here:
    The passenger side wasn't too stiff on mine, but I had a job to move the drivers side. I've heard of some people needing heat to fee them off, so I guess I was lucky ..... There's a C clip to remove and a few washers and an O ring - make a note of the order they came off in.
    I wound the nut right one and put the socket on to knock it through.
    These are the parts to keep an eye on:
    And this is the spindle, mine didn't look too bad compared to some I've seen.
    Using the emery cloth I cleaned up the spindle, and also the inside of the sleeve:
    Once this is properly done I lubricated it all plentifully with Coppaslip and reassembled:
    As all good Haynes manuals say "Refit is the reverse of removal":
    My wipers have never been so quick! In all it took me about three hours, but I was faffing about taking pictures, and also gave under the scuttle area a very good clean as I was spraying WD40 in there in copious amounts over the last 6 months in an attempt to keep the wipers moving!
    S3 GAZ, S90GAV and y2blade like this.
    BASS 666's Avatar
    BMW aye right dead on..
    Sep 2010
    belfast
    463
    well done james the only bad thing is you done audi out of a few quid.
    2002 1.9 tdi 130ish brake a4. full reiger body kit, 19 inch rs6 avant rims, eibach springs, home made grill, full leather interior, centre arm rest, quad powerflow exausts, a few engine mods, chrome door mirrors, aero wipers, s line door blades.
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    845
    Wink
    Yeah you should be. and there aren't very many of them. and a rubbish write up.
    **edit** I should add that the above is sarcasm, which I hope is obvious but perhaps not. Excellent job James
    TDiTom likes this.
    Anybody selling a polisher? PM me.
    A4 B6 3.0 Quattro Sport Avant
    Feb 2009
    Very useful post but one thing I would say. The wipers completely seizing up is usually because people spray the linkage with the dreaded wd40. I know because I did this. Freed them off with some '3 in 1' spray and they've been right as 'rain' since.
    Mar 2008
    Dorset
    13,712
    Water Deflector Part Number:
    8E2 819 403 A01C
    14.73 from TPS
    j033y's Avatar
    200
    Cheers for the write up, I really need to sort mine out, I have been using WD40 now for about 2 months, and this weather is slowing them down again.
    Will get a rain thingy ordered from Audi.. is this the best place? who is TPS as mentioned above?
    Looks like it could be a fun day doing it, knowing my look I will lose the ECU or something silly!
    2004 A4 Quattro 190 S-Line - Akoya Silver, Cruise Control, Full DIS, Full interior lighting pack. - Now sold... Gutted miss is already!
    Mar 2008
    Dorset
    13,712
    trevaudi's Avatar
    Nov 2007
    Leeds UK
    Thanks!
    What a comprehensive & detailed effort. I've kept my wipers ticking over with the occasional squirt of WD40 but as soon as the weather improves a little I'll be performing the operation.......thanks again
    Apr 2010
    11
    Avoid WD40 Like the plague, it strips out any remaining grease but is easily washed out!! Use a can od spray copper grease. I sprayed mine last year and they havent slowed since. No need to remove anything, sand anything Break anything!!
    Mar 2008
    Dorset
    13,712
    The use of any lubricant will only delay this, if they've started to slow then you will eventually need to sort it out properly.
    AudiJohn's Avatar
    Aug 2009
    Derbyshire
    49
    Thanks mate for the info, the wife had informed me yesterday that the wipers seemed really slow. I must admit carrying this out today has really tried my patience (what a pain in the arse). I found it to be the drivers side spindle to be seized solid so god knows how they were working. I stripped down both spindles, cleaned then re-packed with coppergrease. What a difference this has made. Just for everyones info if two people are working on the car you can get the wiper linkage out without taking the window scuttle trim off (mine didn't want to come off) by just prising the link bars off the knuckles.
    Price from TPS derby was 68 in vat
    Aug 2011
    Hi, Thanks for such a detailed posting ! - just done exactly the same thing on my A4 (2000) 1.8 petrol model.
    The reason why the spindles lock is because, the the spindle housing (white metal) has two phosphur bronze
    bushes pushed in either end, they do NOT meet in the middle ! - they leave a gap of about 10mm in the middle !
    This white metal then starts to corrode, and it is this white powdery residue that eventually "strangles" the spindle !
    Successful outcome, thanks to your post - many thanks !
    Mar 2009
    449
    A massive thank you to quattrojames for this great DIY write up, without it I wouldn't have had the confidence to take this on and Audi would have relieved me of another few hundred pounds. Had to get help from another pair of hands in the end as I needed one to hold the Ecu and the Ecu box while the other puzzled out and then removed the linkage. As said in the OP and by earlier posts, I stripped it down, cleaned up and lubed with plenty of copper slip and replaced the worn rubber O rings with new ones and it works as good as new.
    Going to try a smear of silicon grease on the top of the spindle and wiper arm nut, just before the plastic cover cap goes on to try and eliminate any future moisture ingress.
    Great result and thank you James.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    Mar 2012
    Excellent write-up with photos. Will be stripping mine this weekend.
    Does anyone know if same (mechanical) problem would be affecting wash-wipe system. Basically, I pull the lever for a wash, and the blooming wipers stayed on for about 5 minutes after. Thinking this is an electronic module controlled function?, I switched ignition off/on again to try and reset, but wipers continued to wipe continuously for 5 mins. Same happens when try the lever flick down with no wash. Anybody any ideas what this may be, and where would the offending faulty module be located?
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    521
    I did this last summer - thanks for the excellent write up - driver's side was the seizing one on mine - right next to a water channel, passenger came out with a tap, driver's came out with several hard taps. I put an insane amount of grease all over the mechanism and for about a month my wipers worked like they were on ecstasy! They've settled down now, working good nearly a year on.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    May 2012
    6
    My wipers were slow for months, until I went on holiday for 2 weeks and returned to find them seized all together. I followed the above guide, apart from snapping a bracket off the linkage, that wasn't in the guide. I ordered the new linkage from Audi, and collected it today. I've spent the day popping the ball joints out of the old linkage to attach the new one. Got everything put back together, put the wipers on, they don't work. They go down the way first!!! What have I done wrong? I could cry. Been stood out in unbelievably heavy rain for around 6 hours. Bad day!
    Mar 2008
    Dorset
    13,712
    Quote Originally Posted by Russi666 View Post
    There was no such bracket on my car, maybe yours is different.
    Presumably you ran the mechanism with the arms off and allowed them to park before you put the arms back on?
    May 2012
    6
    It's was 1 of the 3 bits that you bolt into place on the linkage. No, I just reassembled them, going off a picture from the net as a guide. I'm of the impression I need to take the whole thing out, detach the motor, plug it in and turn it on. When it settles in the stop position, reattach the linkage. But, I could be wrong. Again.
    Nov 2010
    6
    Thanks save me some money and running around...the wipers work like brand new..ready for winter...
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    I gave this a go on Saturday.
    It couldnt have gone any worse to be honest - Monty Python couldnt have done any better.
    Firstly, upon removal of the plastic covering (at the bottom of the windscreen) I managed to chip the windscreen, this then grew to a crack over the day!
    Upon removal of the splined shaft from the wiper mechanism, I missed with the hammer and broke one of the mechanism mounts.
    All cleaned, greased, put back together and re-fitted - only to find that when I re-installed the wiper arms, the wiper blades didnt touch the windscreen in the centre - found that I bent the mechanism slightly when removing the tapered shafts.
    Back out again to straighten - upon re-fitting for the 2nd time The thread snapped off the tapered shaft on the passenger side! (must have weakend it when I was stripping it down) Managed to have a friend drill and tap it for the time being.
    So yeah, I need a new windscreen and wiper mechanism.... Saturday wasnt my day.
    Jun 2012
    Teesside
    392
    Very common issue at the min I did mine Saturday also, went ok till I refitted to realise id forgotten to put the ecu clip back in then when removing again I completely destroyed the scuttle trim, and I had same issue with blades not sitting right, managed to get them done with a bit of brute force, and I threaded one of the mechanism fixings so I slipped a nut and washer behind to hold it in place, on a plus side my wipers have never worked so well...
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    Nov 2012
    Warwick
    37
    Did mind last weekend, got so slow it was dangerous!
    Took it all apart fine, although struggled getting the wipers off without that little puller.
    I couldn't move the drivers side my hand, even stiff in the vice, don't know how it was still moving! Passenger side was fine.
    Just a warning, clamp the aluminium section in the vice, don't rely on the mounting bracket! I was tapping the spindle out 'gently' and tinkle tinkle the mounting bracket fell off!!! bugger. Had to get the areldite type glue out and build it up to give it support and left it a day to cure and give it the best chance of holding.
    Well seems to be holding fine.
    Thanks,
    Tom.
    Aug 2011
    151
    Should the Wiper Removal tool referenced earlier fail - then this thread offers an alternative solution - Wiper Arms Seized Onto Spindle!
    S3 GAZ's Avatar
    Dec 2006
    Renfrewshire Scotland
    299
    Well had the dreaded slow wipers syndrome this weekend. I had read the guide in the past so wasnt surprised to see it happen but thanks to this I knew the solution.
    Was a right pain to get both the arms off and the water deflector panel. Inevitably I managed to snap tear the water deflector on 2 but at least the windscreen stayed intact.
    Got a new panel on order from audi. £16
    Both spindles were seized almost completely but a good soak in penetrating fluid and some toing and frowing and they were off. They was a fair amount of corrosion in the sleeve. Cleaned and some copper slip and hey presto my wipers are better than ever.
    Thanks James to the guide its saved me a fair few eurodollars.
    Feb 2008
    529
    I also did mine this weekend using this guide, only thing I did that wasn't mentioned was used hot soapy water on the scuttle panel, I cannot compare it to using without soapy water, but one I got it lifted at one end it practically jumped out into my hand
    S3 GAZ likes this.
    Audi A4 Avant 1.9TDI Quattro Sport 2004
    S3 GAZ's Avatar
    Dec 2006
    299
    Quote Originally Posted by S90GAV View Post
    That would have been a great bit of info to have as. Probably would have saved me wrecking mines. But its only £16 I suppose.
    Just happy I never cracked the screen.
    Maybe the guide could be updated to include the soapy water bit
    S90GAV likes this.
  28. #27
    Mar 2008
    Dorset
    13,712
    Cheers guys, I'll amend the original.
    S3 GAZ and S90GAV like this.
  29. #28
    Nov 2011
    Lowestoft, On the Edge, England
    This is a brilliant thread! I've just done my partner's 2002 B6 Cabriolet this morning and as you said, it took about three hours from start to finish.
    I would add that the scuttle panel is quite easy to remove by twisting it upwards in the centre section fairly firmly until it snaps out. It can then be followed along by twisting upwards on both sides to the ends. For those about to do the same, the panel is held in place by a barbed lug that runs the length of the panel. This locates in a narrow channel directly under the screen. By twisting upwards it is pulled forward slightly until it pops out.
    I couldn't believe how tight the off side spindle was! It took some knocking out, so much so that the sleeve inside the cast alloy bit was displaced downwards which I had to tap back into place using a couple of sockets. Without this adjustment, I couldn't get the circlip back into the groove as it was too low and hidden below the top washer.
    Thanks Quatrojames for the post, it must have saved me, like others have mentioned, hundreds of pounds should it have gone to the local Audi dealership. (It's cost me more than any other car I've ever had btw. Don't get me started on the cost of engine oil).
  30. #29
    andy.l's Avatar
    Aug 2013
    Bristol
    130
    Changed my water deflector,aero wipers and overhauled the mechanism the other week,great write up with really clear instructions,made my life a lot easier
  31. #30
    RyanJonS4's Avatar
    Drive It Like You Stole It
    Mar 2009
    Oldham
    273
    My wipers were so seized on 3 years ago when i did this i had to heat 1 of them with a blow torch to free it as I didnt have a removal tool at the time. In doing this i melted a bit of the wind deflector in the middle so bought a fresh 1 from audi. I never got around to fitting the fresh deflector and its that long ago that my wipers have slowed down yet again and need re-doing!
    This time I've got the fresh deflector and a wiper romoval tool at my disposal but was wondering if anyone knows how much a fresh mechanism would be from audi?
    Ryan
    Milltek non-resonated cat-back - 15mm MTM spacers - Toyo T1R's all round - RS4 Pedals+foot rest - Blackout model front grilles - Custom black front badge - de-badged boot - R8 oil cap - silver indicator bulbs - Dodo Juice supernatural wax - ECS tuning Porsche cayenne brake kit ready to fit or sell?...
  32. #31
    Mar 2008
    Dorset
    13,712
    I think I've heard they're £80-100.
  33. #32
    RyanJonS4's Avatar
    Mar 2009
    Oldham
    273
    Think I'll just rebuild mine again then for that money, audi should be giving them away for making such a hash of the original design!
