AH FabricationsJMB Retrofits
Results 1 to 9 of 9
    sniffy_smiffy's Avatar
    Mar 2010
    115
    Help Please ASN - Brake light trouble
    Every time i attempt DIY i regret it.. I am so annoyed.
    Simple Stuff intially:
    - Both rear brake lights stopped working (High Level Boot brake light OK)
    - Brake light switch faulty when scanned with VAGCOM
    New OEM Brake light switch fitted (local mechanic)
    Still no brake lights, so I removed the rear drivers side cluster only to find bulb is OK & new one does not work either ?
    When fitting the cluster back again realised the screw was no longer there to screw the unit back in ?
    It must have dropped down inside the car chassy somewhere and I cannot find it? I will have to buy another from Audi i guess? How annoying Ahhhhh
    Any useful tips for my next attempt ?
    I checked Fuses #7 ESP & Brake light switch & #14 Brake lights. These were Both OK
    Not sure what to try next folks ???
    Any guidance would be hugely appreciated?
    Regards
    Smiffy
    This is my latest set of faults from VAGCOM
    Chassis Type: 8E - Audi A4 B6
    Address 01: Engine
    Controller: 8E0 909 518 AL
    Component: 1.8L R4/5VT 0003
    Coding: 0011501
    Shop #: WSC 63251
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Controller: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04475
    Shop #: WSC 06435
    1 Fault Found:
    00526 - Brake Light Switch-F
    36-00 - Open Circuit
    Address 09: Cent. Elect.
    Controller: 8E0 907 279 C
    Component: int. Lastmodul RDW 0606
    Coding: 00001
    Shop #: WSC 63251
    1 Fault Found:
    01312 - Powertrain Data Bus
    79-10 - Please Check Fault Codes - Intermittent
    Address 46: Central Conv.
    Controller: 8E0 959 433 BD
    Component: Komfortgert TBF 1511
    Coding: 07115
    Shop #: WSC 63251
    2 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01366 - Opened Due to Crash Signal
    36-10 - Open Circuit - Intermittent
    Address 56: Radio
    Controller: 8E0 035 186 L
    Component: concert II GRO 0001
    Coding: 01001
    Shop #: WSC 63251
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
    Audi A4 Avant 1.8T Limted Edition 2004 Manual (30k Miles) - Akoya Silver - S-Line Bodykit - RS4 17" Alloys
    Heated Leather/Alcantra Seats
    My Ex's (Some not so desirable !! ahemm...)
    VW Golf 2.3 V5 170BHP
    VW Polo 1.2 C Formel E - The Beast .....
    Ford Fiesta 1.6 Si
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    brake light switch incorrectly fitted IMHO
    Mar 2010
    115
    Quote Originally Posted by Byzan A4
    Cheers Byzan I have heard they are quite tricky to fit. Will probably have to buy another as they can break easily ?
    Ford Fiesta 1.6 Si
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I have a pdf guide for fitting the brake light switch. PM your email to me and I'll send it.
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    best way to check the switch is to 'bridge' the wires if possable
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    the new switches are just push in, turn, click, and turn again until the unit is square with the clutch switch if installed, iv fitted 2 now in 2 cars,
    Mar 2010
    115
    Thanks for help chaps I have a nice shiny new pdf guide in my inbox ready to give it a go, kindly provided by Mr QuattroJames. Will post how it goes, hopefully it will just be the switch. Regards smiffy
    Ford Fiesta 1.6 Si
    Nov 2011
    I quattrojames,
    I have the same problem that is described in the topic.
    Can you send me the great PDF, please?
    Thanks,
    Rui Teixeira
    Mar 2008
    Dorset
    13,856
    Send me your email.
