Volks AutosAH Fabrications
    cocain's Avatar
    RAA RAA like a dungeon dragon!
    Aug 2004
    The Sticks
    170
    Question Windscreen demister problem
    My windscreen de mister has suddenly stopped working. Does anyone know what the problem can be. the rest of the heating and aircon seems to be ok but when I turn it on to demist there does not seem to be the forceful gush of air that usually comes out of the top vent pointing up to the windscren.
    anyone had this??
    thanks
    Audi A4 TDI 130
    Remap
    18" Alloys
    Electric heated leather recaro interior
    Lowered bilstein suspension
    Alpine cd player Genesis amp Jl sub
    Ipod ashtray mount
    Audi A8 LWB 4.2 TDI
    19" 12 spoke alloys
    Walnut Trim
    Walnut steering wheel
    Silver Grey Platinum Leather interior
    Audio upgrade removed bose
    Audison bit one
    Morel speakers
    Genesis Amps
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    It's most likely the motor that moves the mechanism has failed. Costs about 70 from memeory, but you can move it to the position you want by hand in the meantime. See here:
    HELP! windscreen demister
    Oct 2010
    Hampshire
    294
    I've just had the same problem and wasn't sure if the servo had lost strength (as it still worked when removed) or if it was the resistance in the flap mechanism. Very easy to remove the glovebox, 4 bolts along front, 2 below, one behind side panel that pops off. Refitted the motor and it was working for a bit, but unplugged it in the demisting position and think I'll leave it like that as i dont think it ever would need to be closed.
    Green is for the defroster flap - 8E2 820 511 B superseded by G
    Red is for the left hand side temperature flap - 8E2 820 511 A
    Blue is the Air recirc flap 8E2 820 511 D (G135)
    There is another motor under the drivers side for the RHS temp flap
    If you put a new motor in you may need registered VAG COM to align it by going to the HVAC module, Basic settings, block 01. This cycles all the HVAC motors to their extremities.
