JMB RetrofitsVolks Autos
    Oct 2004
    Best Oil for Audi TDI
    Hi
    I constantly get the oil light flashing on my dash. The oil was only changed recently along with the filter and oil pressure switch. The light comes on every 10-15 minutes once the car has warmed up and then goes away, 10-15 minutes later it comes back again.
    Is anyone else getting this problem? Its getting quite annoying now.
    After some snooping around and I think it may have something to do with the type of oil I used (I used diesel of course, just one from a high street). Is there a specific one I should use for best performance???
    Can anyone pin point what the problem may be, thank you in advance!!
    Slips ( Audi A4 1.9 TDI 1996)
    Any help appreciated
    imported_oilman
    Re: Best Oil for Audi TDI
    If your car has the PD (pumpe-duse) engine than the oil you should be using is a PD oil which carries the VW code 505.01 the viscosity is 5w-40.
    If not then the code would be 505.00 which is either 0w-40, 5w-40 or 10w-40.
    Simon
    imported_kris_tdi
    you dont have the pd engine if your is a 1996 model.
    imported_oilman
    The factory fill is by a German Company called Fuchs Lubricants.
    They supply VAG with 15,000,000 litres per annum.
    Their oils and the specs are on my website.
    Simon
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    Yeh Fuchs do make some of the best lubricants and will have any oil for any job! Don't be put off by the name is't top quality stuff way better than any high street castrol stuff.
    imported_oilman
    They're just a bit hard to get hold of as only available through specialist outlets.
    You can always contact us. Tech details on all of their high performance range are here:
    http://www.opieoils.co.uk/lubricants.htm
    Simon
