    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    auto windows not working
    since disconnecting and reconecting the battery the windows dont operate on 1 touch, is this just a case of recoding and if so, which section will it fall under, cheers
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    As far as i know from my A3 it takes a few times of opening and closing the windows for them to relearn the auto function i would imagine this to be the same on yours.
    26,773
    hold the window switch fully up & down few times to reset auto windows.
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    You need to 'teach' the module by pressing the window button down/open and hold it for 5 seconds when fully open and then pressing and the holding the window button up/close for 5 seconds, after that it should work as 1 touch again
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    scott b's Avatar
    1,254
    nice one, cheers guys
    T0m
    Sep 2007
    Lichfield
    452
    Or simply when the window is shut just pull up the switch as if to close the window again and let go...
