Well I completed Cruise tonight. I am greeted by a little green symbol on the dash when i play with the cruise switch. oh the joys... Everything went smoothly, just followed the PDF that is posted earlier. I used a spline as opposed to torx but each to his own. I trimmed my lower cowling with a hot cutting knife. There is actually an outline already there where the cut should be.
When it came to coding I had the usual messing with logging into the ABS module. I worked out my login from the logs I had done previously. And then forgot to login the second time with the code provided in the PDF. But thats my fault.
Whilst I had the steering stuff off I also cleaned my dash clocks out. split it down and blew it with compressed air.
All back together now... cruised home.
PS. Forgot to bring the battery for my camera...hence no pics.
As for fitting the cruise and driving with out using VAG to set it up. You will have 3 warning lights. One is red, the handbrake. Red means don't drive. The other 2 are orange. I doubt you will have ABS, your steering could be affected too. I would be unsure myself about driving like this.
