Chris NottSky Insurance
Results 1 to 13 of 13
    jd26's Avatar
    Apr 2010
    s.wales
    266
    spigot ring help asap!
    Hey folks!
    New wheels have arrived only problemo with the spigot rings.
    Boxes show the wheel hub = 57.2
    Spigots have little numbers showing 73.1 on the outside and 57.1 on the inner...sound right for the a4?
    They dont fit in the backs of the wheels though :S seem to have an extra lip on them but its thick thick plastic so surely wont just break off...
    confused..
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    is the OD of the spigot ring supposed t be 73.1? i.e. is the bore of your wheel 73.1mm?
    edit;
    if the bore of your wheel is 57.2 then you wont need spigots to fit over your standard VAG hub bore of 57.1 mm
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    jd26's Avatar
    Apr 2010
    s.wales
    266
    rings in question - guy said on the phone that it should have a lip that cuts off..
    not sure buddy not checked as i just expected them to sort that for me.. just seems odd as on my last car it was just a case of plonking them in the back of my new wheels not messing about
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    yep, i dont believe you would have to cut anything off. I have recently gone through the trouble of fitting spigot rings to some aftermarket wheels. I bought the exact same spigots you have there (ID 57.1, OD 73.1). They wouldnt fit.
    What wheels are you trying to put them on?
    Alex S3 AMK
    jd26's Avatar
    Apr 2010
    s.wales
    266
    a set of r36 omanyt reps buddy.
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    have you measured the bore of the wheel? You should be able to get an idea of what it should be
    Alex S3 AMK
    jd26's Avatar
    Apr 2010
    s.wales
    266
    Just got out there now and test fitted a wheel without the rings. They appear to be the perfect fit for the hubs. Good times! just gotta wait for my missing valve and then the tyres will be on them woop!
    Thanks Alex!
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    cool good times
    Alex S3 AMK
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    You need some type of spigot ring as Alloy and steel don't mix well, one will react against the other.
    AUDI A4 190T S-LINE.
    BASS 666's Avatar
    BMW aye right dead on..
    Sep 2010
    belfast
    463
    just grease the hub with good grease..
    2002 1.9 tdi 130ish brake a4. full reiger body kit, 19 inch rs6 avant rims, eibach springs, home made grill, full leather interior, centre arm rest, quad powerflow exausts, a few engine mods, chrome door mirrors, aero wipers, s line door blades.
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    unless you can find a 0.1mm spigot i would also suggest that grease would be the best option
    Alex S3 AMK
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Quote Originally Posted by CMD View Post
    ALL genuine wheels are direct fit on all cars including Audi so if they fit all the better plastic spiggots are after market wheel only
    yes alloy and steel dont mix but as already said i slight smear of gold grease is fine
    but so many OEM wheels have nothing and dont give trouble .
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Very strange for after market/replica wheel's to fit direct as the supplier included the spigot ring's.. When i bought ATS cup's a month or 2 back for my project polo, we had the same problem with the the spigot ring's not fitting the wheel's. Rimstyle sent us down 3 type's to try. VW forum member's at the time said use insulating tape on the hub's to make up the difference..
