Badger5Volks Autos
    Oct 2008
    Newcastle upon Tyne, United Kingdom
    85
    A3 wheels on a A4 Quattro Sport
    Hi,
    I have ended up with a set of 5 spoke 17" A3 alloys (et56) 5x112. Can I fit these ok with spacers on an A4? I believe these alloys in the correct fittment are ET45
    looking through some threads it seems to be popular to offset the front/rear so was thinking a 20mm at the back and 15mm at the front, or 15mm rear , 10mm front?
    Anyone had any experience of this?
    52 A4 Avant 1.8T Sport Quattro
    Metallic Atlas Grey
    Leather/Alcantara, Xenon, F&R PDC, Ambient lighting, Storage pack, Interior lighting pack
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    As long as you us hub centric spacer's and longer bolt's you should be fine.. I use spacer's on mine ET44 + 15mm spacer rear's and ET44+ 10mm spacer up front.
    AUDI A4 190T S-LINE.
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    But NOT too long on the bolts or you'll shred the ABS rings!
    LostBok/BahnStormer77
    Xattica's Avatar
    Dec 2009
    Hi,
    At the end what do you do? I'm thinking about some A3 sport wheels (et57) 17" for my A4 B5 Avant. What spacers and bolt you used?
    Thanks.
    Oct 2008
    85
    Hi
    In the end I used the wheels (et56) with a 15mm spacer all round. Wheels just sit nice in the arches now. They have a very slighty , more modern look than the same alloys with the correct a4 fitment. I don't know if there is a slight difference in the design.
    Be careful as I believe the b5 uses a different standard offset than the b6.
    Was supposed to be a cheap set of wheels that didn't work out so cheap in the end after 100 for spacers! We live and learn
    Metallic Atlas Grey
    Xattica's Avatar
    Dec 2009
    Thanks for the info.
    The B5 OEM offset is 45mm. Currently I'm on OEM 15" (205/60). But, the wheels can be used without spacer or the rubbering is too much?? At the end I'm plannning go with 15-20mm spacer, but later.
    X
