AH FabricationsChris Nott
Results 1 to 7 of 7
    Jun 2010
    13
    Aaaaargh wet footwell!
    Was getting some stuff out of the back seat and noticed that my rear driver's side footwell is absolutely sodden! I can't see where the water could be coming from, no sunroof or anythin - is there a common leak spot that ends up at the back? Like maybe a leak under the front scuttle works it's way to the back?
    Cheers in advance!
    P.
    Jun 2010
    13
    Just found out that the blower has stopped working as well, and the climatronic is doing the same strange display as it did the last time the blower blew a fuse - d'ya think it could be leaking through the pollen filter due to a blocked scuttle drain, down through (fusing) the blower motor, and then making it's way into the back? I didn't get a chance to check the passenger footwell...
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Hey mate, I've heard of similar problems before - take a look at this thread, hopefully it should point you in the right direction....
    Water leak / dripping in passenger footwell when AC is on
    Good luck mate and best wishes
    Chris
    Jun 2010
    13
    Cheers Chris! Problem diagnosed, I think. Went out for a smoke at tea break, pulled the scuttle cover off and it's swimming with water, so looks like I have a blocked drain. Happily my blower motor seems to have dried out enough to work again as well! I'll need to whip the battery out, soak up the water, then go drain-hunting - any ideas where they are?
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    just next to the battery there is a rubber bung, push this out with a long screw driver, then step back and watch all the water piss out
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,712
    I think there's a second one under the battery too.
    Aug 2010
    1,540
    one under the battery tray and one just under the brake servo.
