JMB RetrofitsVolks Autos
    silversurfer's Avatar
    Jan 2007
    221
    Central Air Vents Not Blowing Air
    Hi,
    Has anyone had any problems with the 2 central air vents not blowing air through, I've tried the climate unit on hot and cold and it makes no difference, still no air blown through
    The vent on drivers side and the far passenger side work fine.
    Neil
    Xmay4444's Avatar
    On Point!!
    Nov 2008
    LHR
    255
    Is the A/C unit on Auto?
    If it is then that is the probable cause as the Climate control automatically adjusts the air flow to keep the cabin temp at the set value.
    Try increasing the fan speed (which will disable the Auto), and then press the middle vent switch and see if air comes out the middle vents. If the air does come out, then you have no problem with those vents.
    1.8T quattro S-Line in Akoya Silver, Milltek sports cat & 100mm tipped pipes, black Angel Eyes, 18" RS6's (Vredestein Ultrac Sessanta), Bose Symphony 6CD, Moonroof, Criuse Control, Armrest, Full DIS, 0.5 Leather, F&R PDC, Light Pack, Parrot MKi9200
    Coming soon HID's
    2001 1.8T Sport 0 v Swedish Artic 1
    Jan 2007
    221
    Cheers I'll give that a go on the way to work tomorrow.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Its probably a motor/mechanism problem similar to the one detailed in THIS thread.
