Volks AutosBadger5
    Jul 2010
    london
    9
    HEADLIGHT LIGHT LEVELING HELP!!!!
    I GOT A HID KIT FITTED THIS EVENING ALL IS WELL EXCEPT NOW THE AUTO LEVELING NOW DOES NOT WORK ON PASSENGER SIDE LIGHT.
    SOME TIMES IT DOES AND MY PASSENGER SIDE IS OUT OF LINE DRIVERS SIDE WORKS FINE CAN I ADJUST MANUALLY AND IF SO HOW?
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Welcome to the forum.
    No need to shout [CAPS LOCK] is the key on the left of your keyboard - you might want to disengage it!
    Auto-levelling of headlights you mean you have a 0/1/2/3 rotary switch next to your headlight switch?
    If yes this is the Adjustable headlight levelling system on some models originally with Halogen lights.
    You can adjust the headlight levels and orientation with the nylon grub screws on top of the headlights however you need to take it to a garage where they can be set-up correctly - any MOT test station will have one.
    It could be that the passenger side (n/s) motor has been dislodged from it's mounting or there is something stopping the internal adjustment frame moving up and down - take the headlight off and have a look inside the headlight. Perhaps the HID fitter should be doing this, you say "...got a HID kit fitted...."? Have a check that the wires ore not broken to the motor also.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Jul 2010
    london
    9
    thanks very helpfull and im talking in normal tone now!
    Jul 2010
    london
    9
    yes i have the rotary switch,wires seem to be ok somtimes it adjusts be moves slowly sometimes will get it looked at tomorrow thanks for your help
    simon.m's Avatar
    Oct 2009
    2,746
    maybe just a lazy motor on that light mate if it moves but slow ;-)
