Volks AutosMonster Motorsport
Results 1 to 23 of 23
    rob irl tdi's Avatar
    Jul 2010
    241
    serious battery drain problem b6 01 Help
    My mate has a serious drain on his 130 2001. Its almost 7 volts on the multimeter.Pulled ouy all the fuses and its still there. Pulled out the central convience module and its bone dry still a drain.
    We pulled out the central electrics relays and fuses overs the drivers side one at a time and the drain remains on the multimeter at the battery.
    It goes from 7 down to 2 and back up again. This seems to happen while the hazard light switch lights up its self on its own.
    Disconnected the altenator wires too with no luck.
    2001 S3
    26,716
    I was about to say disconnect your radio & test, there have been issues like this with radios mate, but then read your hazard switch issues, have you disconnected that to see if it stops draining.
    Jul 2010
    241
    I disconnected the aftermarket radio and the drain was still there. No I never disconnected the switch itself. Could it be? I no the door lock on the drivers side isn't working. The car cannot tell if it its door is opena a nd the alarm buttons in the drivers door won't light up by pressing them
    That isn't related to my problem tho.
    Is there another relay unit under the Engine ECU?
    Just get low voltage readings with VCDS
    2001 S3
    Jul 2010
    241
    No sound of relays either with that hazard switch lighting up on its own.
    2001 S3
    26,716
    Uh it may well be related to your problem if it is intermittantly thinking doors open or shut as this obviously controls the interior lights aswell, turn of the interior roof lights & see if it improves, the lock has microswitches inside, spray it with wd40 to see if it removes some gunk in the lock, if not remove lock & take apart & clean out, if no luck then change lock, also I'd advise a scan with vagcom & maybe some lock measuring block logs if supported on your car age.
    Yes remove hazard switch aswell, see if anything makes a difference.
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    946
    To isolate the doors completely out of the problem simply unplug the door connectors in the A and B-pillars under the rubber gators.
    One relay by the engine ECU (Plenum Chamber) is the immobiliser relay - this energises the starter motor via a feed from the ECU - doubt if this has anything to do with your problem.
    Are yoy checking the current drain on the battery by measuring Amps with a suitable meter?
    Disconnect one side of the battery and put an Ammeter in line between the battery terminal and the disconnected cable - do not start the car with this meter connected as this will fry your meter unless it is rated at 100Amps or so.
    Measuring volts is not the way to find the drain, if the reading is less than 12v then yes it's not right but that's all you can deduce!
    As you disconnect items / remove fuses the Amp reading should decrease.
    When the car is inactive you should be looking at a figure much less than 1 Amp - I'll try and take an actual reading tonight and post-up.
    Another sugestion - Alarm siren in boot - internal backup batteries corrode and destroy the internal circuitry. This could be causing an unnecessary power drain but would be isolated by removing all Convenience Module fuses.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Probably totally wrong, but I'll pop this reply incase it helps anyone in the future - I had a B5 with the same problem, it turned out to be the amp on the rear speaker - it basically stayed on and drained the battery over time
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,689
    The hazard light switch can fail, see THIS thread.
    Jul 2010
    241
    Oh yea lads I disconnected the door loom at the A pillar. Convience module everything unplugged and still a drain yesterday.
    It could be the switch its self
    2001 S3
    Jul 2010
    241
    Quote Originally Posted by Woorlord View Post
    Sorry Woorlord, its amps. Our friend is a mechanic and we cannot find the problem. The car belong to our mate.
    The door look would not cause the drain even tho its not working the interior light or the symbol on the DIS to let it know the car door is open.
    I had these locks go on me in the mk4 golfs ive owned
    I'll post a scan of it up.
    2001 S3
    Jul 2010
    241
    Here it is lads
    VCDS Version: Release 908.0
    Data version: 20090911
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E12A062793 Mileage: 193580km/120285miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 FP
    Component: 1,9l R4 EDC 0000SG 1467
    Coding: 00002
    Shop #: WSC 63351
    WAUZZZ8E12A062793 AUZ6Z0A0151900
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 1726
    Coding: 04255
    Shop #: WSC 00598
    2 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    00778 - Steering Angle Sensor (G85)
    37-10 - Faulty - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043
    Component: A4 Klimaautomat 0711
    Coding: 00000
    Shop #: WSC 63351
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 B
    Component: int. Lastmodul RDW 1512
    Coding: 00001
    Shop #: WSC 00000
    1 Fault Found:
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655
    Component: Airbag 8.4E 3001
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    1 Fault Found:
    002 - Lower Limit Exceeded - Intermittent
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 F
    Component: Lenksulenmodul 0202
    Coding: 00011
    Shop #: WSC 63351
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 FX
    Component: KOMBI+WEGFAHRS. RB4 D28
    Coding: 00400
    Shop #: WSC 00000
    2 Faults Found:
    00668 - Supply Voltage Terminal 30
    01304 - Radio
    49-00 - No Communications
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0504
    Coding: 00001
    Shop #: WSC 00000
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 AL
    Component: Komfortgert T9F 0514
    Coding: 06859
    Shop #: WSC 63351
    Part No: 8E2959802B
    Component: Trsteuer.FS BRM 4.11
    Part No: 8E2959801B
    Component: Trsteuer.BF BRM 4.11
    6 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01561 - Left Rear Door
    61-00 - Won't De-Safe
    01559 - Drivers Door
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    2001 S3
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    supply B+ too low doesnt necessarily indicate a drain or short, rather an intermittent break in the power to the wire or circuit common to the parts that show an error code.
    A fuse in the ECU compartment may have blown, or power to the central convenience module (fuse again or relay) may be intermittent in the same way.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    defsix's Avatar
    149
    Quote Originally Posted by rob irl tdi View Post
    You should be measuring DC Amps not volts. Measuring volts won't tell you anything useful in this circumstance.
    AUDI A4 Avant 1.9TDi Sport
    | RS4 RARB - RS6 18" - SLCR Spolier - HID's / Laminex / DRL's - Ext LED lighting - Ambient Lighting F+R - Dension300 / iPod Touch - Siemens Bluetooth - DIS - Cruise|
    Jul 2010
    241
    Quote Originally Posted by evilscotsman View Post
    Cheers we'll heave a look at the Ecu and relays in there and see tomorrow.
    The car did get a new battery before andit drained it in a couple of days
    2001 S3
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    On from my previous post #6, indicating you should be checking out the current drain in Amps.
    As promised, using my Fluke 87 DVM with 10A current range with 100ms recording function, (sounds good anyway), here are some "good" figures for comparison......
    All doors closed (not locked), Bonnet up, Hazard switch backlit illumination OFF, I think most systems have shut down and the current values vary as follows:
    min=32mA / max=76mA / Average=40mA
    Open the drivers door (interior light already set to off) and the drain shoots up to 2.871A
    Dash board mileage and clock light up, door red warning lights come on, drivers footwell light on, etc.
    After shutting the drivers door again, the Hazard switch light stays on for a while then turns off and the current drain drops down to 2.409A
    After a short time (minute or so) systems start to shut down and current drain drops gradually and reverts between 32mA and 76mA as stated initially.
    Hope this helps?
    Jul 2010
    241
    Thanks Woorlord, but i'm still none the wiser on this car
    I've swapped my hazard switch wit mine and it is doing the same.
    After locking it the harzard light stays on which is normal and then goes off.
    It starts flashing later on and off which it is not nomal
    and thats when we get the amp reading up and down on the battery
    Forgot to say too the you can hear the doors kinda clicking forsome reason too. Don't know if this is linked to the fact theat we know his drivers door lock switch is fecked
    I haven't tried the ECU of whats under it yet but that the last place I have to check if there is a relay of fuse gone.
    This car have been with a few mechanics that are puzzeled.
    2001 S3
    Sep 2003
    Bournemouth
    312
    Have you tried disconnecting the wires going to the alternator? If a diode goes short circuit it can back feed causing a largish drain, the alternator will still show good readings when operating. I've seen this several times on various makes and models and the drain is normally over 4-5 amps.
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    Jul 2010
    241
    Yes the alternator was disconnected and still a drain on the multimeter
    2001 S3
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    946
    It would be good if you could put some meter reading figures to your tests on removing fuses, switches, alternators - you are always going to get a current drain if the battery is connected it's the magnitude and duration that decide how long your battery can provide the relevant power.
    Please give us some "A" or "mA" readings.
    Jan 2012
    North west
    Hi
    I was just wondering if ever got the bottom of this issue, as my car has the same symptoms!
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    i also know someone with the same issue !!!! with the central locking not working now..... on previous threads the alarm siren/battery back up always pops up's have you checked this out
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Feb 2011
    littleborough lancs
    207
    i had the verry same problem on my old a4,( 2.0se 130)
    the hazard lights switch was staying on for ages. the battery was dead within hours, evan a brand new 1 at a cost of £145 from halfords didnt do the trick
    2 auto electricains, an audi garage, and a few loacal garages could not sort this thing out, BUT when you say " no the door lock on the drivers side isn't working. The car cannot tell if it its door is opena a nd the alarm buttons in the drivers door won't light up by pressing them
    That isn't related to my problem tho."
    dont be fooled,, it more than likly is, trust me
    i had a 7.5 amp draine on mine, did all the things your talking about and nothing sortid it out, when all the fuses wer put back in, here it is againe was the cry. it droped to just over 2 amps when the (after market) cd/dvd player was taken out, fitted it to another a4 and everything was ok?????? amps looked at and all fine, DOOR LOCKS LOOKED AT AND???????? BINGO, (so thought) disconected and everything was ok, all the lovley amps where back where they belong,,in my (yet another) new battery, but all the locks and windows and blinking led light etc etc were working fine when they were connected, so god know why.. all pluged back in and checked out againe and the amps still droped but only 4 this time,
    after A LOT of digging, turns out it was the locks, and a little un known about speeker/mic for a hands free kit hidden right under the dash that was going faulty,
    kit taken out stamped on a good few times, and the door locks pizzes through with a good blast of wd40 and,,, they lived happley ever after ,,,the end
    Jul 2010
    241
    It was the central convience unit in the end. It was dry but must have been damaged before
    2001 S3
