Forge MotorsportRevo Technik
Results 1 to 20 of 20
    jd26's Avatar
    jd26 is offline 1st Gear
    Apr 2010
    s.wales
    256
    Post Thanks / Like
    Service trip meter
    Had a service not long after getting the a4 and the garage have tried twice now to reset the service timer and its stillll come back the same after going to '-----'s for the first few hundred miles..
    Helppp
    Google Adsense Circuit advertisement
    Advertising world
    quattrojames's Avatar
    quattrojames is offline Moderator
    Mar 2008
    Dorset
    10,040
    Post Thanks / Like
    It will stay like that for 5-600 miles until it resets itself, then it will give a mileage and time countdown, don't worry.
    2003 A4 Avant 2.5TDi Quattro
    To do: Replace HID's with 4300k & replace led's & main beam bulbs - Lamin-X tint headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    MDA
    MDA is offline sploorer
    Dec 2009
    86
    Post Thanks / Like
    mine does the same
    i think it adjusts the next service according to your driving style etc
    brownie 25 is offline 1st Gear
    Apr 2010
    182
    Post Thanks / Like
    how do you actually reset it as i done the service myself
    simon.m's Avatar
    simon.m is offline 6th Gear
    Oct 2009
    2,428
    Post Thanks / Like
    im sure its 500miles or 4 to 6 weeks what ever comes first
    jd26's Avatar
    Apr 2010
    s.wales
    256
    Post Thanks / Like
    Yeah its done that both times James, thing is after the few hundred miles of '---' its coming up with the mileage and time countdown again but the same as it was pre-service
    simon.m's Avatar
    Oct 2009
    2,428
    Post Thanks / Like
    are you saying when its reset it is on --- for say 500 miles then it gose back to say 9600miles or 36weeks as its meant to do that its counting down
    jd26's Avatar
    Apr 2010
    s.wales
    256
    Post Thanks / Like
    it goes back to somthing like 8,600 miles which isnt the fill intervall if you get me?
    simon.m's Avatar
    Oct 2009
    2,428
    Post Thanks / Like
    i think it is on some if you add the 500 to it it takes it to 9100 miles so its seems right to me mine whent back to 9600 i think but audi have two service kinds long or short so id say it was ok if im wrong some one will happly tell me im sure lol
    Mar 2008
    Dorset
    10,040
    Post Thanks / Like
    Quote Originally Posted by jd26 View Post
    That sounds right to me, what are you expecting it to say?
    jd26's Avatar
    Apr 2010
    s.wales
    256
    Post Thanks / Like
    atleast 10k? when its just been reset?
    Mar 2008
    Dorset
    10,040
    Post Thanks / Like
    The standard service interval is give or take 9k I think, like Simon said by the time you've done a few hundred miles it normally says 8500 or so.
    jd26's Avatar
    Apr 2010
    s.wales
    256
    Post Thanks / Like
    Ah fair enough then aslong is it sounds right thats fine, wasnt due one for 8k when i had the car but peace of mind and all that haha
    Cheers then lads
    paul20v's Avatar
    paul20v is offline Audi fanatic
    May 2009
    S.Wales
    1,092
    Post Thanks / Like
    With a diagnostic machine you can set them to different intervals
    someone asked about resetting
    as far as i know it can only be done with a diagnostic tool straight away ,
    i didnt actual realise they reset themselves after so many miles as ive always reset them straight away .
    Mar 2008
    Dorset
    10,040
    Post Thanks / Like
    I think you need Vagcom to reset it when it's on longlife servicing, but AVS can be done locally.
    paul20v's Avatar
    May 2009
    S.Wales
    1,092
    Post Thanks / Like
    Mine was on longlife variable ,
    but i reset it with the diagnostic machine in work and put it back on standard service intervals .
    PetrolDave's Avatar
    PetrolDave is offline 4th Gear
    Nov 2003
    U.K.
    726
    Post Thanks / Like
    With VAG-COM you can reset it for both fixed servicing and AVS.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version 8P0 035 193 C inc SDS, HW 070, SW 0200), Bluetooth + HTC Touch HD
    Apr 2010
    182
    Post Thanks / Like
    vag com is not needed.
    press and hold the spanner button,
    turn on ignition then release the spanner button,
    press 00 button and dis will say ---- or service,
    switch off ignition,
    job done
    Mar 2008
    Dorset
    10,040
    Post Thanks / Like
    Quote Originally Posted by brownie 25 View Post
    job done
    As mentioned previously, that works for AVS but not long life servicing.
    simon.m's Avatar
    Oct 2009
    2,428
    Post Thanks / Like
    im thinking my car has been change at some point audi have it as longlife but i rest it myself on the dash and it come back with 9000 so dont no what one of the two owners befor me did that but shows it was looked after as they wanted to drop the oil more than audi lol
