AH FabricationsEM Tuning
Results 1 to 9 of 9
    Mar 2007
    61
    LED SIDELIGHTS + POOR FM RADIO RECEPTION
    Hi
    the problem is ive installed some 5x led sidelights in my B6 QS
    ive noticed that when i put on my sidelights im LOSING FM RADIO STATIONS ?
    any ideas why ?
    they are not giving any warnings on DIS .
    do i need resistors or just different LED sidelights ?
    Can anyone link to known good Led SIDELIGHT BULBS
    Thx
    Cheech
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,722
    I get interference from my HID's, but not my sidelights, have you got HID's?
    Mar 2007
    61
    yes got 4300 k HID
    am getting fm radio interferece with sidelights switched on
    if i remove sidelight bulbs and replace with other 501s NO FM PROBS
    so am taking it that its the LEDs
    thx
    Cheech
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    i had the same issue when i installed LED brake lights, in the end took them out i also have HIDs
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Mar 2007
    61
    its looking like its the HIDs thats causing FM probs
    any one know a soloution ?
    its not causing any prob when i put on sidelights with normal 501s( as it was with LEDs)
    but put headlights on and a loss of signal is noticable (also TMC has line through it on RNS E ?)
    signal loss is not as bad as with LEDs fitted but still losing some strength (a few fm stations go grey )
    thx
    Cheech
    Dec 2008
    Blackpool and Watford
    133
    Do you have both aerials fitted on your RNS-E.
    When H.I.D.S power up they do emit a lot of RF, after a minute or so that calms down, making sure you have both aerials fitted and working helps, but is not a 100% cure
    Mar 2007
    61
    @blackpool
    yes both aerials fitted ,
    i have noticed when driving about that its about 80% better WITHOUT leds , but when in a built up area then signal goes completely ,
    is there anyway of eliminting this with boosters or earths ?
    thx
    Sep 2010
    12
    One of my friend is also encountering the same problem. He encounter the same interference when the sidelights is on. Do you think replacing a whole new set of turn signal assembly will eliminate the interference or do you have any suggestions about it? It is quite annoying whenever me and my friend heard it.
    Leaky Lloyd's Avatar
    Apr 2010
    280
    solution?
    try a decent cd,
    snoop doggs always a good choice!!!
