Results 1 to 11 of 11
    will89's Avatar
    Jul 2010
    362
    Condensation in headlights
    Since fitting HID's i have had a gradual build up of condensation in the lights. Earlier today i took the units out and dried them out with a hairdryer. I used sealant to seal the black rubber grommet in the back plate of the unit for the wires to the ballast. I have now got condensation again and its driving me mad!!!
    Any Advice?
    Will
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    The lights are vented, so sealing the rubber thing wont have made much difference.
    Audis answer (which may not work mind) is to run the main beam and headlights for 10mins while stationary to heat the light units up and dry them out.
    TD5 Land Rover Defender build
    will89's Avatar
    Jul 2010
    362
    Will go give that a go and see what happens.
    will89's Avatar
    Jul 2010
    362
    Have tried this now but still no luck. There is still condensation in the lights
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I've got a dead fly in one of mine
    simon.m's Avatar
    Oct 2009
    2,746
    as silly as this may sound try putting the small bag you get in a box with say new shoes not sure what its called mind but its to stop things getting damp so may help
    Mar 2008
    Dorset
    13,856
    Thats a good idea Simon, they're called Silica Crystals.
    Mar 2009
    470
    Will, as Aragorn suggested but try it for a bit longer. Next time you go for a half hour or so drive switch the headlights on and the heat should dry out the moisture. I had the same thing after I bought my car I had condensation in the headlight unit and realised that because i hadnt driven it at night and not had the lights on, the condense couldn't evaporate. I tried mine initially for ten mins or so but it didn'd clear, so then tried it for 30 mins and it cleared it completely. As long as you have no other faults with the unit, this should work. Well it worked for me anyway.
    Hope this helps,
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,265
    me too and the remains of a daddy long legs, but there is a cover missing from the back of both my headlights!
    paulsb's Avatar
    May 2010
    lanarkshire, Scotland,
    138
    Quote Originally Posted by swarcup View Post
    i have a new driver side dipped beam and a old main beam cover if you want one, bought it because the old cover was cracked and i haden't noticed that the headlight casing was cracked.
    pm me your address if you want it.
    Apr 2010
    152
    me too!!!!!!! going to pull headlight bulb and feed a small flexi hose attached to a hoover to suck it out 'cos it's pissing me off.
