EM TuningAH Fabrications
Results 1 to 8 of 8
Thread: Faulty coil
    TURBOTRONICS's Avatar
    Jun 2009
    186
    Faulty coil
    I think one of the coils has gone on my 03 s4 v8 but not 100%
    Its seems to have dropped a cylinder and the engine management light is on
    I have ordered a coil which should come tomorrow but will the engine light go out once the new coil is fitted or will i have to have the fault codes erased
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Audi coil pack's are known to fail so it's good practice to carry a spare.. The AA charged me 40 for one.
    AUDI A4 190T S-LINE.
    Jun 2009
    186
    Was that the reason you called the AA if so what happened to the car
    How did it feel I mean and did the light come on on the dash and did it go out again once the new coil was fitted
    Sorry if im barking up the wrong tree
    coyote's Avatar
    Dec 2007
    203
    If the coil has failed your car will probably be in limp mode also (no power at all above 3k) . To reset the fault code you will need vagcom or I think disconnecting the battery for 10 mins will clear it also.
    SerialAudiOffender
    Aug 2010
    Scotland
    100
    I think any fault code reader with a reset facility will be able to get rid of the fault code and engine management light.
    Jun 2009
    186
    if i disconnect the battery will this not affect the rns e is it coded
    Jun 2009
    186
    just changed the coil and plugs while i was doing it and hay presto sorted it i just need some one to clear my fault codes now thats in the wigan area
    coyote's Avatar
    Dec 2007
    203
    You can buy a cheapo lead complete with vagcom off ebay for around a tenner and clear the code yourself.
