Sky InsuranceAH Fabrications
Results 1 to 7 of 7
    cfoster's Avatar
    Essex
    237
    Audi S4 Avant slight knocking at the rear? Any ideas?
    Hi all, got a 2003 S4 Avant (B6) and recently started getting a slight knocking noise from the rear passenger side wheel area, only seems to be if I go up a bump slightly at an angle (ie - pull up onto my drive, front passenger wheel first, then drivers front wheel, then it knocks as the rear passenger goes up). Seems to only happen in similar situations and sometimes very rarely at low speeds over rough / uneven roads. Only the once though, if I reverse slowly off, then try it again it wont do it!! Only if I drive down the road and back to the drive!
    What the first thing to start checking? Are bushes prone to going on these or top mounts etc? It does have an RS4 anti-roll bar on there that was fitted before me buying it.
    Chris
    AudiiduA's Avatar
    Midlands
    358
    Id be looking at the anti roll bar bushes! i have a similar driveway by sounds of it! causes the odd clunk ect but only every now and then! possible drop link???
    cfoster's Avatar
    Essex
    237
    yeah sounds similar, doesnt sound too bad but something id rather sort before the winter comes!! I'll take a look under there tonight!
    cfoster's Avatar
    Essex
    237
    Well just got around to jacking it up to take a look, to my amazement where the passenger side rear anti rollbar bolts to the top of the droplink, there is no bolt there!!!! It lines up but obviously when going over bumps etc it knocks the lower wishbone. It did have an RS4 anti-roll bar fitted a few months before I bought it but fook me, the bolt isnt anywhere to be seen!!
    Does anyone know what size / type bolt should be in there before I started buggering around taking the other side off to see?
    Jul 2007
    London
    3,252
    Go and buy a new bolt and nut from dealer as they are 1 time use only !
    FOR SALE:
    cfoster's Avatar
    Essex
    237
    yeah ordered one today, only 48 pence!!!! Just hope it hasnt stuffed the thread on the top of the droplink.
    cfoster's Avatar
    Essex
    237
    Well fitted bolt last night and all is good!! no more knocking . Easy 48pence fix!!!!
