Sky InsuranceAH Fabrications
Results 1 to 9 of 9
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    2.5 TDi Quattro AKE 110k service, what & where?
    The family wagon is due its next service (just over 110k).
    The timing belt is I think due every 60k although the service book is confusing and it could be 60k or 80k. Anyway, I think it needs doing.
    What else should I have done on this service seeing as the car is getting on a bit?
    I remember reading that I might as well have the water pump done while the front end is off, anything else worth doing while it is off?
    other things that I think need doing are:
    brake fluid, brake hoses, fuel filter, oil change & filter, air & pollen filter.
    other things that I'm not sure about:
    gearbox oil - does this not need changing at somepoint?
    coolant, no mention of this needing changing - just topping up. would like to change this myself and clean out the reservoir as its very dirty. anyone done this? is it easy? thinking about putting the reservoir tank in the dishwasher If I can get it off easily.
    quattro system - does this need any sort of mainance?
    anything else that need looking at/changing/checking that I've not thought of?
    and finally, any recomendation where to get the work done, preferably somewhere in the north west?
    will be giving the local stealers a ring for a quote as well as stoke & stafford audi, also volk service in blackpool.
    Thanks very much for any advice/recomendations
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
    Jul 2007
    770
    does the book show when these items were last changed? the belts etc should have been done about 80k .I dont think the gearbox on a quattro needs anything .The coolant res are only 12 new and easyto change
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Audi recommend 80k for the cambelt, most specialists will err towards 60k as being plenty. While the front is off it's also worth doing both tensioner and idler pulley, along with water pump, thermostat and also fuel pump belt. Some may see this as over cautious, but I speak from experience.
    I personally do oil, air, fuel and pollen filter each service. I'm not sure of the brake fluid change interval (is it in the book?) but it would be nice if you're doing brake pipes etc.
    Coolant can be tested to see if it's ok. Again if it's never been done it would be good to do it, waterpump/thermostat change will probably see to it anyway.
    I 'think' the quattro system is sealed for life, but I'm not 100% sure, would be nice to find out though. I don't know about the gearbox change either I'm afraid.
    Are you anywhere near Awesome GTi? I've heard good things about them, but I don't know the area at all.
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    Thanks for your replies.
    I had the cambelt done at audi stoke at 67k(they've put + waterpump as well in the book), the book gives conflicting info on when to do the camshaft drive belt. It says 60,000 for "TDI engines with unit injector system" and 80,000 for "V6 TDI engines". I've rung audi twice and been given a different answer each time!
    The brake fluid was done just over 2 years ago and it says in the book every 2 years.
    I was thinking I might see If I can get some braided hoses for a reasonable price while I'm having them changed.
    I do the air, pollen, oil filter & oil change, brake pads & discs myself. Is it easy to do the fuel filter yourself?
    Awesome GTI isn't too far from me, I might check them out.
    I'm unsure now weather the timing belt need changing on this service or the next
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    also try PSI tuning in stoke, they know there stuff, and are pretty cheap on labour charges
    mikeh126's Avatar
    Preston, UK
    152
    I also came across conflicting information about when Audi recommend the cambelt change. I had mine done shortly after I bought the car, at 76k.
    I know it's always best to err on the side of caution - if the timimg belt lets go, it's mega-bucks to put right - but if you've only done 110k now, and the belt was changed at 67k, that's only 43k miles ago. I personally would have it changed at the next service (120k?) BUT - peace of mind is everything!
    Haven't changed the fuel filter - so don't know how difficult it is.
    I've also heard good things about Awesome, but have never used them.
    2003 A4 Avant 2.5TDi 180 Quattro Sport in Light Metallic Silver, Remapped to 220 by ProTec Motorsport, RS4 18" x 8J reps, Falken F452 tyres, 10mm H+R Spacers, Matt Aluminium Mirror Covers, Heated Mirrors, S4 Door Blades, Continental TS830p Winter Tyres on 5 star 17" Sport Alloys
    scott b's Avatar
    1,254
    awesome did do the cruise control on my car, no complaints about the work except the under dash trim wasnt cliped in, one hit later it was sorted.
    subaru swift's Avatar
    Jul 2010
    staffordshire, some where
    153
    psi did my lowing springs on my old a4 tdi 1.9, i had a mate there so i got a good deal .
    however awesome is good too from what i hear off my folks,,,,,,,
    2004 AUDI A4 2496 cc 2.5 TDI 180 Quattro Sport
    Metallic Silver, RNS-E Audi dvd Sat Nav ( 2010 dvd disk ) + muti CD Player, Parrot ls3200 Bluetooth Phone kit, 6 Speed, 4 Electric Windows, Electric Mirrors ( not elec folding ), Cruise Control, Nice Alloy Wheels, Colour DIS, Colour Keyed Body, Full audi Service History, Maintained Regardless Of Cost, Tinted Windows, Aero Wipers, inside red light kit ( audi ) + Puddle lights & Footwell light too, HID's.
    scott b's Avatar
    1,254
    psi, have done loads on my car even befor i owned it, hence why i went back there to get the coilovers replaced
