Sky InsuranceJMB Retrofits
    London, United Kingdom, United Kingdom
    121
    ABS and Traction control light just came on
    As per title guys, this came on during my drive to work. I pulled over and switched off the car and had a good look under the bonet at the levels and stuff. I did notice the brake fluid was not on max but nothig else jumped out at me, pleanty of meat on the pads and the rubber is still legal. Anywai i got back in the car and started to drive off, not the lights are off. After a few miles and a tap of the anchors and hey presto the lights are back on.
    Any ideas?
    2002 A4 1.9tdi se 130 saloon in Grey. STANDARD
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Get a VCDS/VAG-COM scan - should tell you straight away.
    Where you based?
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Brake light pedal switch
    I have a pdf guide to changing it if you want to PM me your email.
    121
    in in enfield but i work in ROmford, near Gallows corner
    121
    Well i picked up the spare part and just my luck on the way home the lights went out. Im just waiting for them to come back on again.
