Volks AutosEM Tuning
Results 1 to 8 of 8
    Oct 2009
    Hull
    1,433
    heres one for ya!!!
    i have a 2002 1.9 tdi since i got it its always taken quite a few turns befor the car fires up even when it had been running for a while!! i also noticed the coolant temp sensor had gone belly up as it was only reading 70 degrees! so thought it could be this!
    changed the sensor and the temp starting reading right now the car will sometimes fire up straight away and sometimes take a few seconds on the key!!
    now i went to show one of my mates this and at the time it was a bit dark so i had my lights switched on and it started first turn every time!!! but as soon as i turn the lights off it was back to starting after a few seconds on the key!!
    i can get in the car turn the key and it will take a few seconds before it fires yet if i get in put the side/head lights on it will fire straight away!
    any ideas?
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    have you had the car scanned?
    Oct 2009
    Hull
    1,433
    nope cant afford the 60 +vat to get it scanned just yet!!
    just seeing if anyone has come across anything like this before
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    946
    Where are you based - perhaps someone nearby can VAG-COM/VCDS and save you the 60+VAT?
    Any sensor problems will show up on the scan. - so much simpler than guessing.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Aug 2010
    1,540
    youve got me on that one. it shouldnt make any difference. if it helps any.... you have an odd fault there!
    Oct 2009
    Hull
    1,433
    Quote Originally Posted by Woorlord View Post
    im in Hull yorkshire
    i think its time to get some overtime in and buy a VAG-COM for myself!!
    Garfie's Avatar
    Jul 2009
    Ipswich, Suffolk
    179
    My 1.9 TDi has the same starting issue, sometimes it starts straight away, other times it takes a few cranks before it goes. Doesnt make any difference if the engine is hot or cold either. I havent got to the bottom of it yet.
    Never noticed if it makes any difference if the lights are on or not as I generally start it with the lights off.
    Current Car:
    A3 S-Line TDI 140bhp Sportback in Misano Red Pearl with Audi Open Sky System, Chrome Roof Rails, Full Leather, Front Armrest with Audi Phone Prep, MFSW, Cruise Control, Auto Wipers, Auto Lights, Auto Dim Mirror, Rear Parking Sensors, Bose Stereo, Privacy Glass, Ambient & Footwell Lighting and Puddle Lights.
    Pic soon
    Gone but not forgotten:
    Audi A4 TDI Sport Avant in Denim Blue
    VW Golf Mk4 GTTDI
    Vauxhall Calibra 2.0 16V 150bhp Red Top
    Vauxhall NovaVAN 1.5TD
    Oct 2009
    Hull
    1,433
    Quote Originally Posted by Garfie View Post
    i usually start with the lights off i figured it out when dropping a mate off and it was a bit dark i turned the car off to show him but left the lights on!! it started everytime first turn!!
    so you going to flick your lights on now to see if it fires first go ? lol
