Results 1 to 18 of 18
    Mar 2010
    16
    Buying my first audi, how to tell if Sline
    hello lads am going tommrow to buy my fisrt audi a4 1.8t 190bhp sport sline it's a 53 plate but 2004 model, but how can i tell if its a genuine sline and not just a sport
    all it says on the log book is: audi a4 1.8t sport thats it dose not state sline anywhere on the log book, on the cars 2 rear door mouldings it says sline dose that make it an sline or is there more to it how can i tell what am buying is a sport or sline
    any help would realy be appriciated
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Errm I'm no expert here, but it should have a S-Line steering wheel badge (iirc), perforated leather wheel apparently, and also metal embossed S-Line kick plates. They're the things which are often deemed too expensive to replicate.
    Were the S-Lines released as early as a 53 plate? I'm not sure.
    The engine code will confirm it's the 190 model, hopefully someone with one can confirm what that should be.... And the T in the 1.8T should be red, although this can obviously be changed.
    jd26's Avatar
    Apr 2010
    s.wales
    266
    It should definatley say on the logbook dude.
    No embossed steering wheel on mine / others ive seen but side blades, sline side badges, boot spoiler and obviously the kit are some things to look forr
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    2004 was the release date. My engine code is BEX. As QJ said the S-Line badge should be on most thing's inc steering wheel. Also 18" wheel's as standard
    AUDI A4 190T S-LINE.
    Aug 2009
    833
    Mine doesnt have the S Line badge on the steering wheel, but it has everything else so i wouldnt always expect this.
    Mar 2010
    16
    no dose not say s-line any where besides the rear door moulding, it has the sline kit and the side blades but comes with 17's and not 18's?
    also what should i look out for when going to buy it =, its done 90000miles and has fsh
    Mar 2008
    Dorset
    13,856
    Sounds like a Sport then mate. As has discussed (many times!) previously.... the later model Sports came with an S-Line "style" bodykit including door blades.
    Mar 2010
    16
    thanks for the advice lads is there any thing i should look out for when going down to view the car, are there any common faults with them.
    Mar 2008
    Dorset
    13,856
    The 1.8T's can be vulnerable to oil sludge, blocking the pick up and starving the engine of oil. Results vary from killing the turbo to wrecking the entire engine. Do a search, there's LOADS on it!
    Reference the other issues, have a look here ..... link
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    the door-sills are the expensive add-on people don't normally do: should have metal embossed S-line plates in the scuff plate on each door: about 500 for the pair plus painting, so only the TRULY dedicated will stump up for that!
    LostBok/BahnStormer77
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Check the history of the car, the car should have had a new timming belt (due to the high miles) , water pump, belt tensioner ect,oil changed on a regular basis. Worn suspension arm's.. I would hold onto my money as 90000 mile's is high.... How much is the car.. Check these out
    http://www.autotrader.co.uk/classifi...ge/1?logcode=p
    simon.m's Avatar
    Oct 2009
    2,746
    i would have to say after reading all the above the only real way to no if its s.line or not is have a look on the log book
    if its not there then its not an s.line and he or she should have no problem showing you the log book.
    Mar 2010
    16
    no dose not sate on the log book as an s-line, i think it a 1.8t 190bhp sport
    dose 4000 sound resonable price or could i get better for my money
    simon.m's Avatar
    Oct 2009
    2,746
    does it say sport on the book then i have a sport tdi and on the book its a sport sorry if im coming over wrong just no there is many fakes out there but as for the price id say its ok
    Mar 2010
    16
    yes on the log book it states:
    audi a4 1.8t 190bhp sport, 53plate but first registered in 2004
    4000 sound like a good price tp pay for it.
    simon.m's Avatar
    Oct 2009
    2,746
    i think 4k is good but im not to sure when it comes to the 1.8t as i have a tdi but id pay it for the right car where i am in the uk they are going for far more but dont buy it if your not to sure as said above there are otheres out there for less but if its a good car and your happy with it thats all that matters really although would not hurt to try and hit him for lower in cash ie 3850 ish
    Aug 2009
    833
    plug the reg into euro car parts to see imo.
    http://www.eurocarparts.com
    mine comes up as
    Model A4 T QUATTRO S LINE (B6)
    Engine Size 1781 cc
    Engine Model BEX
    Manufactured 2004
    Registered 26-04-2004
    Transmission MANUAL
    Colour RED
    But there is a bit of scene tax i'd say on this car, they are few and far between to find all three in one car, Quattro, S line and 190bhp version
    Theres a few on Autotrader but not many.
    i bought mine for 9k last year and they still go for 8-9 now even with the extra milage i put on it.
    simon.m's Avatar
    Oct 2009
    2,746
    if audi do one thing its hold there price verry well more so where i am
