Results 1 to 16 of 16
    Aug 2010
    12
    Hi and garage recommendation in south
    Hi!!
    Just bought a 2003 S4 avant 60k FASH, drove 400 miles and was loving it, now I have a vibration that came on after a high speed run, the garage I have it in can't corner the problem
    Any suggestions for a specialist in the South who is familiar with the Dualmass problem? thinking it may be this
    Aug 2009
    833
    Storm Developments have always been good for me.
    dsmclark40v's Avatar
    Sep 2006
    Hampshire
    715
    Where about in the south are you? on my last audi when the flywheel started to go it would only judder when pulling away. Does it always judder or is it just at speed?
    Sam,
    Gone
    Aug 2010
    12
    thanks guys, car is with garage who have confirmed dual mass fly, but 1600? does that seem about right? have contacted storm dev for a price as well
    In and around Bournemouth area...
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I've always heard good things about Kartechnics in Poole, but dsmclarks recent experiences would make me a bit hesitant in recommending them. Autotechnics in Gillingham are very good.
    Sep 2006
    Hampshire
    715
    Oh just noticed to Audi-sport! Where did you buy it from? was it private or trade?
    Is that parts and labour? is so that's probably not far off as the dual mass flywheels aren't cheap. ask for a breakdown. You thought of changing to a single mass? JH Motorsport in the US do a clutch and flywheel kit that is what I would consider if I were in your shoes Click
    Sam,
    Gone
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by kerniki View Post
    Hi!!
    What, no warranty?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Aug 2009
    833
    ECS Do a aluminium fly kit too, and that would rev like a motorbike :D
    Aug 2010
    12
    dsm - yep, parts and labour inc vat
    bought private, 300 miles later.....
    are non original parts advisable? am getting a quote of 1250 elsewhere all in
    Sep 2006
    Hampshire
    715
    That sucks, mine didn't last about that after I bought it and a timing tensioner broke. Luckily I had warranty to cover the cost
    problem with non genuine parts is that it could go again not long after and then you would have to get it done again.
    Was that quote with clutch being changed as well? how much did they quote just for parts?
    Sam,
    Gone
    Aug 2010
    12
    ended up at kartechnics, LUK parts are being used so original back door audi, no? 12mth guarantee on parts and labour but hoping to not need it
    clutch is an addition if it is needed, we suspect a new one was fitted not so long ago and if not contaminted, should be ok.
    Aug 2010
    12
    thanks Sam, all done and dusted now and back home, Kartechnics were great and very competitive on price, i understand you've had a bit of a run in with them so cant comment on that but they really did help me out so have to give them a shout.
    Sep 2006
    Hampshire
    715
    Glad it worked out well for you . They are nice guys, but it was just silly things like they overfilled the oil by 2 litres, missed off a hose clip on a vacuum line, used a screw to blank off a line and told me the car was running fine when it wasn't (turned out it had a spilt hose) and then got a bit funny and cagey with me. They were probably pissed off as they had to take the engine out again at their expense which is quiet labour intensive. I was just unfortunate and my car was probably just a one off...
    How much did it cost you in the end? you've made me paranoid now about my flywheel/clutch as my clutch pedal feels funny and thrust bearing a little noisy
    Sam,
    Gone
    Aug 2010
    12
    1500 inc vat.
    seem to have some under trays missing this morning and I'm sure they were there before
    Sep 2006
    Hampshire
    715
    1500 inc vat.
    Same thing happened to me! but I wasn't 100% I had them before it went in as I didn't look under there. They might have forgot to put them back on
    Sam,
    Gone
    Aug 2010
    12
    sorry for long reply...
    to be fair it appears they were not on the car when I purchased, just never noticed when I inspected.
    Car has not missed a beat since the initial drama thanks for your help on the matter
