Sky InsuranceAH Fabrications
    Dec 2009
    Chester
    19
    Rear wash wipe removal audi a4 avant 2004
    Hi All
    Does anyone know how to remove the rear was wipe on an audi a4 avant 2004.
    There is a piece of plastic that has snapped or has worn at the rear of the wiper the bit that makes it spring back with pressure and I want to take it off an put a metal pin in its place.
    Any ideas greatly accepted
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Add Jimmeh on Facebook
    Ive just done this; remove the inner trim on the bootlid and you should be able to locate the (x3?) 10mm bolts. Pretty simple after that. (hardest part is removing the trim pannel!!)
    Audi A4 Avant 1.9TDi 130 Quattro Sport.
    WhiteDetails.co.uk - Facebook? Follow me!
    Dec 2009
    Chester
    19
    I've tried removing the inner trim, four screws and it pulls down to a pint but there is somthing holing the trim in place!
    Quote Originally Posted by Jimmeh View Post
    Dec 2009
    Chester
    19
    did yours have the same issue, no spring back?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Its been done before HERE and how to remove the trim is detailed HERE
    Dec 2009
    Chester
    19
    It seems I was barking up the wrong tree, The arm of the wiper is U/S so I,ve managed to prise off to have a look, as per all audis its a piece of plastic that has worn, hence no spring back on the rear wiper, you don't happen to know the part number for the wiper unit do you?
