Sky InsuranceEM Tuning
    alcoholic pervert
    Nov 2008
    Chalford - the Cotswolds.
    195
    Windscreen replacement - anything to watch out for?
    Need the front screen replacing after a stone smashed it today. The insurance uses Autoglass. Is there anything I need to watch out for or do I just trust them to do a good job?
    Are all the glass tints the exact same colour, and the blacked out bit at the top the same depth?
    I assume they'll have the wipers and plastic scuttle thing off which should come off easily since I put the new wiper mech on not long ago.
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Pretty straight forward job as you describe - had mine done ~4 weeks ago (3rd in 7 years) by Autoglass.
    If it was the winter I would be careful about the plastic scuttle below the wipers as this can be brittle when cold and the inter-locking strip can break off.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    alcoholic pervert
    Nov 2008
    195
    3 in seven years? unlucky fella!
    Odd how the cracks spread isn't it? There was like a 4 inch 'spiders web' immediately when the stone hit on the way to work. Now it's the whole height of the screen.
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    On the A4 here is quite a lot of body behind the black area's of the screen, and that is where I always seem to get a stone hit and here there is no give.
    Small 30mm cracks end up across the screen before too long.
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    personaly would order a new scuttle panel, around 15 from audi, had to take mine of to do the wiper linkages, there a right twat to get of without breaking
