Chris NottJMB Retrofits
Results 1 to 7 of 7
    Jul 2010
    Oxford - UK
    Unhappy Door Handle Cover Re-fitting
    Help Please,
    I have just bought an A4 2.5TDi Quattro Sport and the drivers door handle cover has come off in my hand.
    It seems to clip on somehow and utilises a spring plate as well to secure. For the life of me I cannot get the handle to go on and stay on. I am not sure which way round the spring plate should go and does the cover clip over or slide on or combination of both?
    Any ideas or photographs of which way spring plate fits would be most welcome along with how to refit cover in correct manner.
    Kryten
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    this happened on mine. the cover would go back on but as soon as you touched it it fell of, got stuck back on with tiger seal (windscreen bond)
    mattyboyc's Avatar
    Sep 2009
    1,224
    As above common problem get some spoiler glue off ebay ( very cheap ) and stick the bugger back on.
    A4 AVANT 1.9TDI 130 SPORT:
    18" RS6'S//TWIN EXHAUST//ALLARD EGR DELETE//AERO WIPERS//B7 KEYS & ENGINE COVERS//BLACK OPTICS //FRONT & REAR S-LINE BUMPERS//TAILGATE SPOILER//S4 HEADLIGHTS,GRILLS & DOOR BLADES//RS4 RARB & PEDALS//FRONT,REAR & FOOTWELL AMBIENT LIGHTING//PUDDLE LIGHTS//FAN JETS//MEDIA SYSTEM//T.V//7" HEADREST MONITORS//REAR BLINDS//REVERSE CAMERA// CRUISE & DIS
    pjmspeedy's Avatar
    Dude, what's mine say ?
    Apr 2008
    North West
    1,057
    Audi actually use a credit card to get it back on!
    put it in place, hold the handle up and slide the card down the back and slide the spring thing accross.
    Audi A4 1.8T Sport Cabriolet-Full black leather(Electric & heated),RNS-E,BOSE, OEM Bluetooth,RS4 Mirrors,RS4 FBMFSW,RS4 Pedals,RS4 RARB,Cruise Control,B7 Rear Lights,Ally Inlays,18" RS6 Alloys,HID's/Auto lights with dimming rear view mirror,Coming home lights,Ambient light pack & Rear parking sensors.
    For all your VAG OEM PARTS send me a PM or e-mail me at vagoemparts@ymail.com
    190 S LINE QUATTRO
    somerset
    81
    The handles quite often come loose, the best bet is to get a new stainless steel clip from audi, you could try bending your clips out with a small screwdriver but take care not to scratch the paintwork. As pjm speedy above, work out which way the clip needs to slide to lock the outer painted cover on, from memory, the drivers side is foward and passengers is backward, or vice versa! Place the cover on and using a credit card (tesco club card just as good) between the door and handle you should be able to just about slide the card between the crack and push the clip the correct way to lock the outer handle in place. Lifting the door handle also helps. Mine came loose again a few months later so i removed it and put some dow corning rtv onto the handle and repeated the steps above.
    Jan 2009
    North Wales
    33
    Happened to me too!
    Make sure you use an old credit card though!
    There used to be pics posted on here somewhere of how to fix it.
    Mine got chipped when it fell off so had to touch it up.
    1post's Avatar
    Aug 2012
    Post
    Quote Originally Posted by pjmspeedy View Post
    Just solved this Krypton Factor for my mate, took me a while so here's a picture for future reference and for anyone else trying to work out how to do it. As pjmspeedy correctly pointed out you'll need a credit card or small screwdriver to achieve this (it doesn't take much to push it so if its not budging your probably pushing the wrong bit)
    translate:
    Drivers side
    flace-plate side
    PUSH DOWN To lock the face-plate in place
    PUSH UP On this edge to release the face-plate
    Note: this picture was taken with the face-plate removed so the clip is in the unlocked position
    Hope this helps.
Tags for this Thread
