Underfloor aluminium panel - what is it ???
Ingolstadt
NULL
Hi guys,
got an A3 2005 2.0 TDI Sport and have noticed that there is a small aluminium grill on the underside of the car on the drivers side (practically under the drivers seat) that has dropped down on one side.
Firstly - what is it, and
Secondly - how can I hold it in place (looks like the previous bold has sheered off)
Cheers guys
Alan
Common fault - it is the deisel cooler - directly under the drivers seat on the underside of the car?
Mine came loose - to repair it properly, you have to take the seat out, lift the carpet and put in a new nut and bolt.
The cheap, easy way is to get two cable ties, make a loop, drill a hole either side of the cooler into the plastic under trim and feed the cable tie through and tighten in place.
Mine is still rock solid after 2 years!
Aha!!! Simple and effective, just like me !!
Thanks for the advice. Will go and sort it before my midweek Essex blast.
