AH FabricationsJMB Retrofits
Results 1 to 10 of 10
    May 2010
    274
    Coolant Warning! :(
    Guys,
    Started the car this morning and about 1-2mins after startup I got the Coolant warning(?) on my DIS. not lights on the dash though...
    It stayed for a further approx 3mins and dissapeared before i had a chance to stop. I pulled over at my local supermarket and popped the bonnet.
    the level seemed to be above the min line, and I topped it up a little just to make sure.
    Nothing else happened after that and my temp guage was as per norm (in the middle, think its 90*?)
    Ideas?
    8P Audi A3 2.0TDI Quattro Sport - what a change from my 1.0L CorsaC!!!
    follow me on Twitter - Jonay1990 for #Photography #Aviation #Mil #Automotive #Subsea
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Same happened to me about a year ago. Left the car for a while and the warning stopped. It never ever came back.
    Think the coolant sensor on A3's can be a bit weak/temperamental at times.
    Have you done any electrical work on your car recently? Even as minor as changing a bulb??
    I ask because I had been playing about with the rear lights/battery just before my coolant warning came on.
    Could have just been a coincidence but who knows!
    Jun 2010
    26
    I have seen the same thing several times since owning my car and it always goes within a few mins. It normally happens to me when it's very hot or cold outside, but once the car is warm I don't see it, even after turning the engine on and off. Mentioned it at a service but they said the system was fine and that they couldn't get it to happen.
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    Keep an eye on the ground under the front bumper after a drive to see if there's any stains 9as well as checking coolant level) - mine started leaking and it needed a new radiator
    2.0 TDi 140 S-Line With - S3 Vents l S3 Alloy Pedals l S3 Gearknob I Aero Rear Wiper l X-Treme Bulbs l 09 Rear Lights l Custom Floormats l 18" TTS reps l LCR Splitter I Facelift Stereo
    May 2010
    274
    Quote Originally Posted by aythreee View Post
    Yeah I changed the front dipped lights about a week ago to brighter/whiter bulbs.. (which arent very good IMO!)
    double coincidence? or are we onto something here? :P
    is it even a warning as it only showed on the DIS but the dash light never came on? strange!
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by Jonay View Post
    Hmmmmm... could well be on to something!
    Yeah it's a warning, I don't there is a dash light for low coolant level.
    As for the brighter/whiter bulbs... which ones did you fit??
    I'd recommend these... http://www.powerbulbs.com/product_detail.asp?prod=81
    You won't be disappointed.
    Enter discount code ZXRCX111 at the checkout and you'll get 10% off.
    May 2010
    274
    Will the H1 fit the A3?
    I'm not too clued up on how they differ etc.. I got these H7 bulbs, 25 for the two.. RING XenonMax "Bright White Light with enhanced performance for greater light output" my arse!
    "up to 100% more light on the road" yeah from having no bulbs at all!
    I'll go give them a go.. and if the coolant thing happens again I'll let you know!
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Sorry mate, my bad. I linked to the wrong lights. H7 are the correct fitting.
    Link.. http://www.powerbulbs.com/product_detail.asp?prod=81
    27,114
    Sensor would be my 1st port of call if continues to happen.
    Kriminal's Avatar
    Bristol
    177
    Does the A3 have the same coolant checking system as the TT ?
    If so, take the cap off the coolant bottle, and you'll notice that there will be two probes going into the bottle. Try using a flat bladed knife to scrape off any furring that can develop on the probes, as the same thing happened to my TT 3 years ago and I've not had a single problem since.
