Monster MotorsportBadger5
Results 1 to 7 of 7
    Apr 2010
    182
    2004 A3 number plate not working
    As above, one number plate light isnt working on my girlfriends A3, ive removed the bulb holder and tested it on my car and it works so its not that, anyone know what else it could be as the other one is fine.
    thanks
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    have you checked the contacts on the bootlid chance are they need a clean
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Apr 2010
    182
    yeah i gave them a rub with some wire wool which cleaned them up but still no joy
    27,029
    Have you tested the wiring for voltage & checked wiring back.
    Apr 2010
    182
    no not yet, wasnt sure if there was any onnections that could have come loose behind the tailgate trim? not sure how to get that trim off it felt like i was going to snap it lol
    27,029
    Well checking the wiring with a meter would be a 1st, then remove trim & check behind, its probably something simple, couple of screws & about 8 spring clips holds it on iirc, slowly prise it of so as to not break the plastic fixings for the spring clips.
    Apr 2010
    182
    ok cheers guys, is there anything behind the trim that could have came loose?
