Monster MotorsportEM Tuning
    Feb 2009
    Allard EGR delete kit
    Hi all, I have recently fitted the allard kit to my 2004 A3 2.0 TDi and am looking for a little help.
    First of all do you have to block the little vac pipe from the egr valve and secondly need help finding someone to help turn off the check light with vagcom.
    Recently had engine replaced as it dropped a valve and wrecked itself and since i got it back been losing power as if turbo cuts off. When you turn it off and on again the problem is cleared again. Advised to change the boost pressure sensor and have done to no avail. Any ideas???
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Yes you block off the vac pipe. Just use a small screw or bolt will do. It might help if you say where in the country you are for Vagcom help.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Feb 2009
    Oh yeah i'm in Glasgow. thanks devonboy. I noticed you have sensors fitted to your kit . What are they?
    27,114
    Give Khufu a shout as he's up there, I weill msn him this thread link.
    Khufu's Avatar
    West coast of Scotland
    5,693
    I'm just down the road depending on which part of Glasgow your in. Can run a scan & see what comes back. Not a diesel man but will see if we can interprate results.
    Feb 2009
    Thanks I'm in Milngavie so where would suit you?
