Sky InsuranceChris Nott
    Mar 2009
    East Ayrshire, Scotland
    15
    New brakes required - 2.0TFSI
    Hi,
    I'm looking for suggestions for discs and pads for the front of my 06 2.0TFSI S-Line....they need replaced pretty soon and was loking for an upgrade.
    Are these 312mm as standard or 288mm?
    And for future reference will the 4 pot brembo's from a LCR fit?
    Cheers in advance,
    Adam
    Apr 2010
    35
    Just yesterday i done my fronts on a 2005 2.0TFSI S-line and they are 312mm in diameter and 25mm in thickness. As far as the brembos i havent got a clue.
    AJames's Avatar
    Rally Driver - road Audi S3-8P
    Jul 2009
    Milan, Italy
    123
    I have tried many, and have definitely settled for the following setup:
    - Discs: TarOx F2000
    - Pads: Ferodo DS2500
    - Oil: OMP dot 6.0
    - Braided lines
    This will transform your car's braking, without cold fade or noise. The wear will go down by 80% versus original, but only with all given parts.
    At the beginning, not even I believed in the OMP oil, but it is GREAT! Italian Subaru and Mitsubishi rally teams also use this!
    2008 S3 8P: Forge DV, Twincooler, Short gear throw - CustomCAI - Full Milltek resonated - APR HPFP - PensoTech Custom Map - Sachs Racing clutch/cover assembly - NGK Iridium's - Bilstein B8's, tuned - Eibach ERS Springs- H&R antiroll bars - Bespoke Fixed WRC Camber Plates - Haldex Gen II & Switch - Tarox F2000 disks - Ferodo DS2500 pads - OZ Racing Gran Turismo LM 18" - Michelin PSport PS3's
    389bhp - 49kgm
    From Factory: everything but the sunroof.
    Jun 2010
    26
    Adam, did you get yours sorted? I just bought some black diamonds (KBD971G) which had the right diameter and thickness but when I got them out they wouldn't fit as were too shallow.
    Found a lot of posts recommending black diamond discs, has anyone that has fitted them to a 2.0tfsi got the part number?
