AH FabricationsSky Insurance
Results 1 to 21 of 21
Thread: car shaking
    Jun 2010
    car shaking
    I have got a 2006 A3, 170bhp 2.0 tdi. When it reaches around 50 it starts to shake, not a steering wheel shake more through the hole body. It carry's on till around 65-70 then disappears. If you drive straight through it it's not too bad, but if your'e sat doing say 55-60 mph its very bad. It's there no matter what gear the car is in.k Any help much appreciated. Mooey
    Jun 2009
    72
    Need to have your wheels balanced.
    Jun 2010
    I Had that done its a lot worse than a wheel ballance issue mooey
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    does it pull to left or right?
    2.0 TDi 140 S-Line With - S3 Vents l S3 Alloy Pedals l S3 Gearknob I Aero Rear Wiper l X-Treme Bulbs l 09 Rear Lights l Custom Floormats l 18" TTS reps l LCR Splitter I Facelift Stereo
    Jun 2010
    No its just the shaking
    Jun 2010
    Glasgow
    does it do it when coasting at this speed or only under acceleration?
    Jun 2010
    No when accelerating in ok its just when you are driving at a set speed ie in a line of trafic
    Jun 2010
    Glasgow
    Quattro?
    philipjmarshall's Avatar
    Jun 2010
    swindon wilts uk
    91
    Mooey, could be several things wrong.
    1 - Did you balance all 4? as hi speed wobble always comes from rear wheels.
    2 - It could also be a tyre has bulged or gone out of shape, (common problem at my tyre centre with all the potholes about)
    3 - have you had them (dynamic balanced? weights mounted on 2 planes from rear of wheel and behind spokes and back edge_ this is the most accurate method), or (static balance - one set of weights mounted just on inside back edge only - no were near as accurate, but used my many tyre centres as it easer, quicker and uses less weight)
    hope this helps, let me know.
    philip
    2010 Audi A3, Sportback 2.0 TDI 170 PS, S-line Black Edition,
    Exclusive Suzuka Gray, Exclusive Silver & Black Full Nappa Leather Heated Seats,
    Blue Tooth,Bose Symphony 6 CD - i Pod.
    Bi-Xenon Headlights / DRL Led, 18" Titanium alloy wheels.
    Jun 2010
    Ive just had thought from you said about tyers the car done 102,000 and is making a humming nose wich i thought was a wheel bearing jacked it up no play enywhere maybe its linked mooey
    Jun 2010
    Glasgow
    is it quattro??
    Jun 2010
    swindon wilts uk
    91
    yes it sound like its defiantly a rear tyre problem, its ether worn on the inside edge down to canvas and has delaminated. or its worn "steppy of corrugated " on the rear inside edges, the noise sounds like wheel bearing has gone when it hasn't. you find this a lot with front wheel drive cars also most common if drecional tyres fitted.
    Philip
    Jun 2010
    No its not a quattro ,and can i spot if its got a tye problem by looking mooey
    Jun 2010
    swindon wilts uk
    91
    try swooping fronts to rear see if speed of wobble changes.
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    best thing to do is remove the rear wheels and see if there's any visable damage, if nothing is visable then try swapping tyres front - back
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    it deffinately sounds like misbalancing of the wheels, bad tyres or a warped alloy, possibly i steering rack though i doubt that one
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    222
    Had exactly the same problem ! I needed four new tyres anyway , and when i changed them the problem went away .
    dantdi's Avatar
    Feb 2008
    kent
    511
    Hate to say this but mate had this on his golf. it was the drive shaft.
    Jun 2009
    72
    Have a look at all your tyres, as I had a similar issue on my Caddy van, it turned out to be one of the rears tyres was worn bare in one part.
    Jun 2010
    Well thanx lads i will try the tyers and let you mooey ps breaking a mk1 golf soon if anyone needs bits
    pi quattro's Avatar
    Oct 2009
    Ayrshire
    127
    I had someting similar in a van i had once. Took months to resolve. It was a slight bulge on the inside of a rear tyre. Was only spotted with tyre off the van.
    I couldn't see it when looking as the bulge was probably at the top. When it was at the bottom it looked normal as all tyres bulge at the bottom!
    You can only spot it with the tyres off. Probably a good thing to do in your case and then swap them round too.
    current -
    07 A3 TDI 170 quattro
    rnse,leather,auto lights & mirrors,bose,sunroof,xenons, etc
    previous-
    06 A3 2.0TDI sport quattro - rolled & gone
    06 A3 2.0T sportback dsg leather - gone
    06 A3 2.0TDI sport -gone
    01 1.8T GTI -gone
    01 A4 TDI 130 - gone
