    Jun 2010
    38
    No power to radio
    My mate is having a problem with the radio, He says there is now power to the leads,
    Not sure how he has tested that, But is there a fuse for the radio?
    Or any other suggestions?
    Jun 2010
    38
    Just read there is no ignition live to the wires? Does that mean a piggy back fuse has to be used?
    If so which one is best?
    Jun 2003
    World of my own
    9,813
    Depends if he is referring to the stock Audi radio or an aftermarket unit. There is only a permanent live on the wiring loom as the ignition on is controlled digitally by the CANBUS. So only one fuse to check in the fusebox, but also one on the back of the HU.
    Alex Turner
    Jun 2010
    38
    He wants to add an aftermarket unit, Is his options the canbus (are theyre cheaper places that 50?)... Or a 12v piggy back fuse?
    Apr 2009
    Florida (previously Liverpool)
    655
    Three minutes inside the fuse box with a test meter will give him his answer.
    Here in LHD-land it's fuse position 41, as I recall... but it's just quicker to test than to ask...
    Keith
    Jun 2010
    38
    He doesnt have a multimeter and lives to far away,
    If he was to buy the canbus, would the power problems be solved? And he could work a aftermarket head unit?
    Also would it be fine if he installed a screen unit using the canbus?
