JMB RetrofitsVolks Autos
    Jun 2009
    173
    Rear diffuser help
    I want to replace the current part...
    With the S-line diffuser
    Would I need to change the bumper or is it a straight swap? Thanks
    Oct 2008
    Telford
    2,488
    You need the bumper for it to fit perfect however the later diffuser can be forced to fit your older bumper with a few adjustments to the clips/mounts. Once this is done it does fit flush but for me, it doesnt look quite right unless you have the bumper to match.
    B6 1.8T Avant s line gmbh
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    I thought with it being a 2 section bumper then the lower section would fix onto the origional upper?
    2.0 TDi 140 S-Line With - S3 Vents l S3 Alloy Pedals l S3 Gearknob I Aero Rear Wiper l X-Treme Bulbs l 09 Rear Lights l Custom Floormats l 18" TTS reps l LCR Splitter I Facelift Stereo
    Oct 2008
    Telford
    2,488
    You would be right in assuming that but if you look at the red cars bumper, its a lot mpre straight and doesnt have the ridge in it that the silver one does. As a result, its a slightly different shape
